I think if you look at the bottom end it's clear.
You might also read the tea leaves on the rb26 vs. 2jz because you'll come to the same conclusion.
But like Holdens and Fords, you choose your sides and you live with it and it'll be a cold day in hell before I own a Soarer or Supra.
T.
Then again when you can get gtr stuff and poke it straight into the 25 it adds a different aspect to the equation. Yes I realise you are talking stock but the rod upgrade is cheap and easy.
If anything, my only detraction from the 25 is the ease with which you can overboost the engine and the resulting detonation kills the pistons.
End of the day, horses for courses...and this is a skyline forum so bugger off with yer toyo crap (yes my soarer alternator died today so I'm off toyo)
i think they both sound amazing in their own separate ways, and both have their own better/worse characteristics
id go with this comment...there is a write up in zoom comparing the 1J to the rb26 look it up and read it i dont want to sound bias...
the RB25 is a fantastic engine but as far as 1J vs rb25 no offence but the 1J is better compared to the rb26...
I wouldn't say the 1JZ is better than the RB26, but it certainly is in a class beyond the RB25.
Daresay the reason you don't commonly see serious example of 1JZ is due to the vehicles they were released in (Soarer, MKIII Supra).
The update single turbo VVTi 1JZ is where it is at
The 1JZ might be a "class beyond" the RB25, but I daresay that the rest of the car (R32+ Skyline) is a "class beyond" any comparable Toyota. What do you buy a car for anyway, the strength of the bottom end? You can change that easily. But you can't change fatass porky styling. My "inferior" RB25 is pumping out 220+ at the wheels and I see any point in comparing it to other engines that are capable of holding more power. My engine does the job and that's all that matters.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
