OK.
This car is out or coming out at either of these two yards...
but I'll let you fill in the dots.
* Alli.p.rts
or
* Xtr.me M.torsp.rts
There is a beat in the park next to one of those....
OK.
* Alli.p.rts
or
Hahaha nice sensoring Terry.
Are there people out there who don't get a PPI done on these cars by someone in the know??? Really if you don't take reasonable precautions you sort of deserve to pick up a lemon...
has anyone actually seen the car yet?
Don't need to. If it is the same car that the link is about from haymarket, that car is 100% going to have issues. All the other cars he has have issues (safety and legal issues).
Buy it and see for yourself. For me I know what cars that private vietnamese guy sells. I don't have to physically look at his cars anymore to know they ALL have major problems and fake history/Milage. If he does it to Ferrari and lambo I'm pretty sure he won't think twice about an R34.
The guy is just a cheat. He could bring out a flawless perfect car one day but his reputation for delivering dodgy stuff overwrites everything. That is the problem with buying cars privately.
  • 4 weeks later...
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
