Ok so i bought the car with the big garrett taken off and it had a aftermarket exhaust manifold and tial 38mm wastegate bolted on. Took that off and was going to put stock manifold back on with stock turbo but realized i didnt have any water or oil lines or gaskets or copper washers etc so ive ordered these but theres a few mani studs missing. after somone that can help replace mani studs and bolt turbo back on. Or a workshop etc that u guys have dealt with?
https://www.sau.com.au/forums/topic/360409-need-help-bolting-my-turbo-back-on/
Can u put some pics up of what your talking about will help.
If u need exhaust manifold studs look at justjap.com they have them.
best way to put them in is get two nuts thread them on, then try and do one up and the other undone, this binds them together so you can finsih puting the bolt in. once done undo the nuts in the opersite way as to doing them up.
Not hard just need some tools.
thier is a few DIY threads look for RB25 turbo upgrade on R32 GTST in the DIY section.
Alright thanks heaps ive just ordered one of those rb25 turbos anyway so the thread should help witb any differences. Also the car has been rebuilt and has a 3"exhaust, 3"dump, hi flow cat, front mount, earth kit, microtech lt-12s, soon to have series two rb25 turbo, brass button clutch,
To make around 200rwkw would i need yellow jacket coils, injectors, fuel pump, ?? My mate reckons ill need a fuel pressure regulator?
But what gets me is it previously made 238.3 rwkw with the gt 3540 "dont ask me why they had this turbo on a rb 20 lol" so maybe i wouldnt need any thing else to make 200 to 210 kw??
um.......why are you removing the turbo anyway, sound better than a stock rb25 turbo???
as long as your coil packs work ok, don't bother buying new ones for under 300rwkw, not needed
fuul pressure regulators are over rated, if you have injectors large enough, no need. If you are after the last 10kw from your stock injectors, the fuel pressure reg could be of use, otherwise don't bother,
Aww ok thanks for that, i bought the car minus gt3540 but it came with the stock turbo not bolted on. The rb25 series two turbo will do for now just bought a rb25 wiring loom and am looking for a rb25det in the near future.
But a friend has a rb30 turbo motor that he wants out of his yard for the lowley price of a carton so might look at rb30det also!
Yeah i was thinking i didnt need one after reading martin donnons 15 not haves in performance imports issue 132, but this particular mate owns a 5 ltr vp commodore so i thought he of all people would no lol i tryed reciting what martin wrote but couldnt remember lol
To be honest, don't get too carried away with engine swaps etc..
If you don't have the skills/knowledge or tools to put a stock turbo back on, your not going to be able to complete an engine swap.
Get the turbo, manifold, dump pipe, exhust and cooler pipe work sorted out- get the ecu re-tuned. Then just drive it for a while! Spend some money on brakes and suspension before you go getting into engine swaps.
J.
Yeah im gunna tackle it tho can only try. Ive got tools i hire a shipping container and its on my uncles property he owns every tool you can imagine ( earth moving & truck company ) so thats no drama.
I agree i wouldnt tackle a engine swap until im more confident and experienced and might wait till the rb20 gives out anyway.
The turbo should be here today or tommorow then i can take it to this shop in newy called pit crew and get my braided oil & water lines made up.
I have a high mount manifold with a tial 38mm wastegate but i didnt no if id be worth putting the rb25 turbo on that or stock manifold? Id have to get longer oil lines made ?
The dump is ok unless i wanna make a screamer!
The exhaust is some custom made 3" mandrel bent with a high flow cat. But i liked the sound of the blitz nur spec on my last 32.
The intercooler and hard pipeing kit has been taken off and am currently spraying non gloss black dont want to attract any unnecessary attention.
I definitely wanna get it tuned asap and wanna get cold start sorted.
Atm there just stock brakes painted blue :-P will look into something when i hit eastern creek up.
The suspension consists of nismo adjustable shocks, matched to some sort of red springs dare say pedders, and kkr castor rods, wanna lock out hicas and chuck adjustable everything in it. My last 32 had kei office coilovers i really liked those. Also will chuck in my nismo 2 way at some stage.
Yep
Found your problem
FPR's are only needed if your injectors are maxed out and your to tight to buy new ones, I can understand possibly if your stock FPR breaks and you want to just replace with an aftermarket one. But end of the day stock FPR and correct injectors are the best way to go
Didnt read threw rest of the post but for the power you are planing you should get a upgraded fuel pump.
i brought a walbro 500hp pump from www.horsepowerinabox.com for $160. Bosh 040 is also good just a tad more exspencive but can handle higer HP (rated to 600hp)
Yeah i wanna see if i have a stock one or aftermarket.
My new rb25 series two turbo turned up today its physically bigger than the stock rb20 turbs so thats a good sign hopefully it will handle 14 psi
  • 4 weeks later...
Well the turbo is all bolted on etc but it is running rough heard it needs some nipple welded in to the intake pipe? Could this be the cause? Or maybe afm or a sensor of some kind not sure
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
