The horn relay I got has 5 pins - 30, 85, 86, 87and 87a - there was also a 4 pin one but it had its own fuse in the fuse holder - I already have the wire from battery to boot with fuse holder (50A fuse inside) - I need to get a large 30A fuse which I couldnt find. Is this horn relay and the relay base (connector) sufficient?? The thickest connector wire is only rated at 15A and 105 degrees, 600V and 14AWG whatever that is.. And the ground eye connectors are the small blue ones, also got similar size wire bullet terminals too.
Please advise if these items r ok - and which pin shud I use for pump +ve 87, not 87A?? 87A is closed and 87 is open.
product_3983.jpg CLICK TO ENLARGE
Horn Relay Base
This is a plug in base with cable attached.- Suits SY-4068 and SY-40
Your right man. My bad.
When there is 87a it is connected to 30 even though the coil is not energised. But when the coil gets energised then 87a is not connected.
no
If you use the normally closed circuit, your fuel pump will prime ALL the time until a circuit is passed through the coil (which will be when you turn the car on and the fuel pump circuit is energised) then the fuel pump will turn off.
Normally open is in the open (no circuit) condition when there is no signal
Normally closed is closed (complete circuit) condition when there is no signal
Your signal in this case is your original fuel pump wiring engaging the coil.
Basically if you imagine that the drawing I posted has a circle with 87a where the left hand circuit is incomplete then thats what the 87a will be. Make sense?
Yeah I'm pretty sure thats the right way. Worst case scenario, if you hear the pump priming while the cars off or anything weird like that then change to pin 87a. But I Think 87 is normally open
yes its open, I can confirm that from the diagram on my relay - 87a is connected to the other side of pin 30 (battery current draw) and 87 is not connected to anything.
cheers Ron
Have just wired in my fuel pump at an automotive shop and its done wrong because it keeps running when ignition is off and they only used one of the 2 wires (the yellow/ black one) goin onto pump and hooked both ends of that onto relay 87(goin to pump) and 85 (ecu ign signal). The other wire (green/white) goin to pump from ecu is untouched. Relay pin 86 is earthed by itself only.
Pump has 2 wires - green/white and a yellow/black which comes from a splitter hooked to 3 yellow/black wires. Are these the ground wires or is the green/black ground?? Is the r34 +ve or -ve trigger??
Good news is that now the car is back running smooth as ever and all the missing/pops/power loss/hesitation in low rpms is GONE..
But I still have to take off relay everytime I park or else the pump keeps running! Someone please hepl..
There are two wiring "how to"s in the DIY section. The relay switching signal comes from the original wire, There should ideally be a new heavy duty wire coming from the battery and that goes through the relay to the pump. Take it back to the shop that did it and ask them to fix it (for no extra charge).
There is a heavy duty wire with 30A fuse from battery to pump. But as above, the wiring is just wrong, I know u have to cut both ecu-pump wires and hook them to relay and earth/chassis - in my case as I mentioned above only one of those wires is cut. The workshop guys obviously are not too clever, so I wouldnt let them fk it up some more, besides they closed now.. Its a simple wiring I know, just gotta know which wire is ground and which is original switch wire..
It would help big time if someone can post which color code is which wire on R34s. I have 3 yellow/blacks goin onto one yellow/black that goes to pump. And a green/white that goes to pump. Plus 2 other wires purple and black, goin onto fuel sender..
took it for a drive - better than ever - too much wheelspin when goin on boost which is too dangerous and a big thumbs down - even goin straight downhill - kind of wet road (i know) it wheelspins in 2nd.. I think I have less than/around 220rwkw on my 12psi neo engine, a lot of u guys would class that as pretty underpowered, yet how come most of u in the 270 and up rwkw range are NOT complaining about wheelspin????
Maybe its to do with my HARD cusco rear coilovers??? - not enough grip??? Front is the same tho not so hard..
But first things first, someone please tell me the color code for the r34 fuel pump wiring and which ones the trigger?? my wirings still not proper for now - refer above posts..
thanks
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
