Didnt wana short anything or create a fire lol, so do u think the black/yellow wires are the ground wires - theres three of them goin to one. I tried to call you a few times today. If you comin down to Syd tomorrow to do Sir RBs rewire, I can come see you, if the roads are dry and you are free, then I would like to get it road tuned as well or otherwise Easter??
Oh and my no. is 0416424446, I think it is set to private
cheers
I havent planned with Michael yet. I still havent hadthe balls to ask my fiance yet lol.
U should both drive to my place and ill do it all :) u can cruise up here together.
Ok cut the yellow/black wire. Then disconnect pin 86 from the relay end. Cut the terminal off this wire. Connect this earth wire to the yellow/black wire coming from the pump.
Then the other yellow/black wire that joins to 3 or what ever u said it does needs a terminal on it and connect to pin 86.
Try this
thanks man, going to try this now, did u forget to mention that I need to cut the green/white wire goin to pump and connect the pump end to pin 87 and the ecu end to pin 85? Will do that I think. Please text me ur address
cheers
All went well. Fixed up the wiring to the fuel pump. Road tuned the AFRs.
Needs a turbo to manifold gasket a decent dump pipe an a highflow cat then we will see how it goes on the dyno.
R34 gtt fuel pump wiring is
Green white from pump to chassis earth.
Green white from ecu to pin 86 earth
Black yellow from ecu to 85 positive trigger
Black yellow from fuel pump to pin 87.
Pin 30 battery 12volt supply
Thank u Jez, the tune went great, its running smooth as ever, as you mentioned, need a 3" hiflow cat, turbo-manifold gasket, (dump pipe maybe later) and a re-tune on the dyno for power figures, ign timing maps, more boost, knocking and tuning 4th and 5th gear tuning. And I gotta fix that fuel tank seal as well. So many things to do, need to get it out of my head asap.
I recommend Jez AA++. If any of you thinking of getting a tune(Nistune, Power FC, Haltech) or any electrical / mechanical work, he is one top bloke, DVS Tuning located at Central Coast. Check him out, he was awesome to deal with, +1.
Thanks again mate, you did a great job.
  • 8 years later...
Mine R34 gtt is having the same issue as rondofg all the wirings fkn hacked to bit I followed your wiring above but I'm having a issue as I'm. Trying to wire up a solid state relay instead as I'm running the walbro hellcat 525 and it was melting 40amp relays
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
