Didnt wana short anything or create a fire lol, so do u think the black/yellow wires are the ground wires - theres three of them goin to one. I tried to call you a few times today. If you comin down to Syd tomorrow to do Sir RBs rewire, I can come see you, if the roads are dry and you are free, then I would like to get it road tuned as well or otherwise Easter??
Oh and my no. is 0416424446, I think it is set to private
cheers
I havent planned with Michael yet. I still havent hadthe balls to ask my fiance yet lol.
U should both drive to my place and ill do it all :) u can cruise up here together.
Ok cut the yellow/black wire. Then disconnect pin 86 from the relay end. Cut the terminal off this wire. Connect this earth wire to the yellow/black wire coming from the pump.
Then the other yellow/black wire that joins to 3 or what ever u said it does needs a terminal on it and connect to pin 86.
Try this
thanks man, going to try this now, did u forget to mention that I need to cut the green/white wire goin to pump and connect the pump end to pin 87 and the ecu end to pin 85? Will do that I think. Please text me ur address
cheers
All went well. Fixed up the wiring to the fuel pump. Road tuned the AFRs.
Needs a turbo to manifold gasket a decent dump pipe an a highflow cat then we will see how it goes on the dyno.
R34 gtt fuel pump wiring is
Green white from pump to chassis earth.
Green white from ecu to pin 86 earth
Black yellow from ecu to 85 positive trigger
Black yellow from fuel pump to pin 87.
Pin 30 battery 12volt supply
Thank u Jez, the tune went great, its running smooth as ever, as you mentioned, need a 3" hiflow cat, turbo-manifold gasket, (dump pipe maybe later) and a re-tune on the dyno for power figures, ign timing maps, more boost, knocking and tuning 4th and 5th gear tuning. And I gotta fix that fuel tank seal as well. So many things to do, need to get it out of my head asap.
I recommend Jez AA++. If any of you thinking of getting a tune(Nistune, Power FC, Haltech) or any electrical / mechanical work, he is one top bloke, DVS Tuning located at Central Coast. Check him out, he was awesome to deal with, +1.
Thanks again mate, you did a great job.
  • 8 years later...
Mine R34 gtt is having the same issue as rondofg all the wirings fkn hacked to bit I followed your wiring above but I'm having a issue as I'm. Trying to wire up a solid state relay instead as I'm running the walbro hellcat 525 and it was melting 40amp relays
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
