Remember my car was initially running dangerously lean a/f of around 13.7 and up with the stocko item, so now this new fuel pump has hopefully brought that down to 12ish a/f ratios by supplying the required amount of fuel, hence 'making' the power that shud have been there. yes its in low revs then fine, my sock has got a bit of play, i was thinking that maybe the pump doset have enough pressure in low revs cos of this - then on higher revs, it has built up the pressure??
Just putting a fuel pump doesnt increase the power in the car it just enables it to run more power just like a front mount,you will however make more power when you combine it with such mods as turbo injectors where you require more fuel to be pumped out so not sure what your talking about there.
The problem does sound strange as it is missing then working fine, would have thought it was surging from maybe mounting the pump to high but your saying it in low revs and then its fine.
Yes and no. If the afr was leaner than about 13.5 he would be losing power.
You really need to rewire the pump before the tune. U cant do it after or the tune will be out again.
Dude, 13.7 isn't that lean at all... Besides, a bigger fuel pump won't change anything, the stock regulator is keeping the fuel pressure the same, and the injectors are still opening the same amount, so your AFR won'tt change from a fuel pump swap. I reckon the pump isn't receiving the right voltage, the fuel pressure is dropping and the "misses" are lean spots, but it probably wont detonate at those low revs in that situation, it'll just miss instead...
when is it reading that AFR? under boost? on idle?
and how were you measuring it?
13.7 is lean on boost....
Yeah he didn't mention that, my bad.
Regardless, re-wire your fuel pump, and if it still happens, ask your tuner what's going on.
My x-trail does the same thing, I've tuned it myself, played with EVERYTHING possible to fix it, and have no idea what's going on. It just randomly goes lean and misses, if you apply the throttle @ 1700rpm, worse when cold, I think i've narrowed it down to intake turbulence. But yours sounds like a fuel pump voltage issue...
VERY interested to hear the outcome, good luck dude.
Get the car on a dyno and have someone check it out properly. For all you know you could have a dodgy afm or blocked fuel filter, it could be anything. It prob has nothing to do with the fuel pump at all.
It has to do with the fuel pump dude, before changing to the walbro, this issue wasnt there at ALL, I reckon re-wiring is the go - will get my tuner to do that - how much shud I be paying for that??
I know its simple - relay, and then wire from batt positive etc, grounding, but nobody has any pictures anywhere - I need to know things like how the modified wiring goes into the tank, at what point it is cut and where in the chasis it is grounded etc, as u know the battery in the R34 is in the bonnet not boot. I already got amplifier wiring running from battery + to boot with its own fuse (amp is out), can I use that??? Just connect the relay etc.. Does the relay need to sit in bonnet beside battery?
And I saw the a/f ratios after driving on 2nd to 7000rpms and it showed around 13.7 everywhere on the tuners laptop running nistune. Didnt get it tuned then, and yeah on idle it is around 15, normal driving on boost is high 12s to mostly mid 13s..
Post a pic of ur maf sensor in its current position.
Also what ecu are u running to control the fuel pump voltage for ur returnless fuel system. This is very important for ur setup and a fuel pressure gauge must be input to the ecu.
Yes u can rewire the fuel pump using the amp wiring. But get a relay with a fuse in it. Connect the amp power to the power in of the relay think its pin 30.
Then the current trigger of ur fuel pump ( is r34 neg trigger? Im not sure)if its neg trigger cut the negative going to the fuel pump and connect the ecu side of the cut to connect to pin ? (mental blank. Its the earth pin)
If its positive trigger cut the positive to thr fuel pump and connect the current power in from ecu side of the cut to pin?(mental blank, its the other power in NOT PIN 30)
then pin 87 power out goes to ur fuel pump positive the other half of the above cut wire.
Then negative of the fuel pump wire should be grounded to the chassis. U dont need to remove the fuel pump to do any of this. Use the stock wiring approx 300mm of it anyway.
I mount my relay on the right side of the boot well half way up the side.
Don't have a maf sensor, it has an EMS stinger 4424, uses map sensor for load source.
pump has a constant 12v supply, still running the standard fpr, i'm going to install a aeromotive regulator and reference it to boost, the more stable fuel pressure might fix the missing porblem @ 1700rpm... If I want to run more than 12psi, I need a better fpr anyway, and I think it's generally not up for the job at all.
the stinger has no fuel pressure compensation values, it's got air temp and water temperature compensation tables for timing and fuel, anti-lag, two step, 15 other customisable outputs.
And a fuel and ignition map "override", never learnt to use this.
Can you elaborate on why pump voltage is important in a returnless setup?
PM me if you don't wanna clutter this thread!
returnless systems sometimes rely on the ecu to control voltage to the pump depending on a feed back on what the fuel pressure is at the rail, but because yours has a fuel pressure regulator this might not be the case.
is your wiring to the fuel pump stock ie 12volt constant? did your factory setup have a sensor on the fuel rail?
Returnless setups are a good idea due to the facts that you dont get fuel splash when the fuel returns to the tank and the fuel will stay alot cooler as its not travelling through the hot fuel rail then returning to the tank constantly,
but as we all run a return type system it will work for your setup too.
ok now that i am half awake,
-Pin 30 is power in from your amp power wire
-Pin 87 is your power out ( this goes to the positive side of the fuel pump)
-Pin 86 can be connected to the earth trigger, or if its positive trigger connect 86 to the chassis
-Pin 85 can be connected to the positive trigger or if its negative trigger connect this to a switched ignition 12v source
-then connect the fuel pump earth to the chassis,
doing this will give the fuel pump full battery voltage, but still be controlled by the ecu incase of an accident where the engine stops the fuel pump will stop, and wont pump a tank load of fuel all around the car if the line is ruptured
Hey Jez, thanks very much man, you have been extremely helpful, now all those pins, where are they, are these the pins -30, 85, 86, 87 etc, on the plug going into the white fuel pump plastic cap that seals the tank?? Theres 2 plugs and 3 hoses there. So that means I dont have to open that plastic thingy and take out the fuel pump with bracket as it can be done from above, right? And how do I know which is the positive / negative trigger, and by 'switched ignition 12v source' - that is the battery, right?? Sorry for being such a noob, but in all my DIYs I find this the most confusing as theres no real pics I could find, just diagrams..
Theres so many relays in www.jaycar.com.au - this is the only one with a fuse: can I use this?
cartItem_02.gifcartItem_03.gifcartItem_04.gifcartItem_06.gifcartItem_07.gifCAT. NO. SY4076cartItem_09.gif RRP$8.95cartItem_11.gifcartItem_12.gifcartItem_13.gifcartItem_14.gifcartItem_15.gifcartItem_16.gifproduct_9879.jpg CLICK TO ENLARGE
Automotive Fused Relay - SPST 15A
Designed for automotive applications, these quality relays have an integrated blade fuse and metal mounting bracket. The contacts are rated for 15A, making them suitable for installations of aftermarket horns etc.
* 12V 15A contacts
* SPST
* Fuse included
QTY 1+$8.95 10+$7.95 25+$6.95 Enter Quantity spacer.gifspacer.gifcartItem_26.gifcartItem_27.gifcartItem_28.gif<< RETURN[ Top of Page ]
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
