The horn relay I got has 5 pins - 30, 85, 86, 87and 87a - there was also a 4 pin one but it had its own fuse in the fuse holder - I already have the wire from battery to boot with fuse holder (50A fuse inside) - I need to get a large 30A fuse which I couldnt find. Is this horn relay and the relay base (connector) sufficient?? The thickest connector wire is only rated at 15A and 105 degrees, 600V and 14AWG whatever that is.. And the ground eye connectors are the small blue ones, also got similar size wire bullet terminals too.
Please advise if these items r ok - and which pin shud I use for pump +ve 87, not 87A?? 87A is closed and 87 is open.
product_3983.jpg CLICK TO ENLARGE
Horn Relay Base
This is a plug in base with cable attached.- Suits SY-4068 and SY-40
Your right man. My bad.
When there is 87a it is connected to 30 even though the coil is not energised. But when the coil gets energised then 87a is not connected.
no
If you use the normally closed circuit, your fuel pump will prime ALL the time until a circuit is passed through the coil (which will be when you turn the car on and the fuel pump circuit is energised) then the fuel pump will turn off.
Normally open is in the open (no circuit) condition when there is no signal
Normally closed is closed (complete circuit) condition when there is no signal
Your signal in this case is your original fuel pump wiring engaging the coil.
Basically if you imagine that the drawing I posted has a circle with 87a where the left hand circuit is incomplete then thats what the 87a will be. Make sense?
Yeah I'm pretty sure thats the right way. Worst case scenario, if you hear the pump priming while the cars off or anything weird like that then change to pin 87a. But I Think 87 is normally open
yes its open, I can confirm that from the diagram on my relay - 87a is connected to the other side of pin 30 (battery current draw) and 87 is not connected to anything.
cheers Ron
Have just wired in my fuel pump at an automotive shop and its done wrong because it keeps running when ignition is off and they only used one of the 2 wires (the yellow/ black one) goin onto pump and hooked both ends of that onto relay 87(goin to pump) and 85 (ecu ign signal). The other wire (green/white) goin to pump from ecu is untouched. Relay pin 86 is earthed by itself only.
Pump has 2 wires - green/white and a yellow/black which comes from a splitter hooked to 3 yellow/black wires. Are these the ground wires or is the green/black ground?? Is the r34 +ve or -ve trigger??
Good news is that now the car is back running smooth as ever and all the missing/pops/power loss/hesitation in low rpms is GONE..
But I still have to take off relay everytime I park or else the pump keeps running! Someone please hepl..
There are two wiring "how to"s in the DIY section. The relay switching signal comes from the original wire, There should ideally be a new heavy duty wire coming from the battery and that goes through the relay to the pump. Take it back to the shop that did it and ask them to fix it (for no extra charge).
There is a heavy duty wire with 30A fuse from battery to pump. But as above, the wiring is just wrong, I know u have to cut both ecu-pump wires and hook them to relay and earth/chassis - in my case as I mentioned above only one of those wires is cut. The workshop guys obviously are not too clever, so I wouldnt let them fk it up some more, besides they closed now.. Its a simple wiring I know, just gotta know which wire is ground and which is original switch wire..
It would help big time if someone can post which color code is which wire on R34s. I have 3 yellow/blacks goin onto one yellow/black that goes to pump. And a green/white that goes to pump. Plus 2 other wires purple and black, goin onto fuel sender..
took it for a drive - better than ever - too much wheelspin when goin on boost which is too dangerous and a big thumbs down - even goin straight downhill - kind of wet road (i know) it wheelspins in 2nd.. I think I have less than/around 220rwkw on my 12psi neo engine, a lot of u guys would class that as pretty underpowered, yet how come most of u in the 270 and up rwkw range are NOT complaining about wheelspin????
Maybe its to do with my HARD cusco rear coilovers??? - not enough grip??? Front is the same tho not so hard..
But first things first, someone please tell me the color code for the r34 fuel pump wiring and which ones the trigger?? my wirings still not proper for now - refer above posts..
thanks
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
