Need help from all. As per the topic my GTR won't turn over. Just to give you a background on what has happened. Playing with the GPS at night so i turned on the two reading lights at the front and forgot to turn them off. After I closed up i always chuck my CTEK trickle charger on to keep my battery going when i don't drive during the week. GTR is only for the weekend drives. So i when i go to start on the Saturday night discovered battery was drained and found out the lights were on. So i had to jump start however it wouldn't turn over. seems like its not getting sparks or no fuel is getting injected. I have checked the fuel pump and its pumping fuel. Looked at error codes and i get code 55 - No Malfunction. I'm lost as what the problem is. Thanks in advance for the help!!!
https://www.sau.com.au/forums/topic/360453-my-r34-gtr-wont-turn-over/
how long did u have the booster cable connected while trying to jump start it.. if your battery is really flat, it still may have trouble starting.. try swapping in another battery.. or get a multimeter out to check voltage.. sounds like battery
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
