For Sale: 6 Splitfire Coil packs for the R34 GTT or Stagea RB25DET NEO
Condition: Used and working perfectly unsure of age
Price: $250
Uploaded with ImageShack.us
For Sale: ALLOY INTAKE PIPE - R33,R34 or STAGEA , fits on stock turbo and Z32 or factory AFM very easy to install - more of a better sound and suction even louder dose lol
Condition: Still pretty new a few scratches
Price: $60
For Sale: R34 AFM with K&N Pod
Condition: Used not, good condition
Price: $80
For Sale: 3inch X-Force Full Exhaust system with 3inch Highflow Cat + 3inch Dump pipe - Fits factory r34 turbo, Nice note, very nice roar when on boost
Condition: Scratches around the exhaust the usual.
Price: $500
For Sale: GTR ZTUNE fiberglass bonnet. Its fits perfect awesome quality.
Condition: Just been sprayed black recently 1month old
Price: $400
For Sale: R34,R33 Hicas ISC lock bar - Both wheels will be stable good for drifting :)
Condition: Few months old its just a bit dirty
Price: $50
For Sale: R34 Rear Whiteline Swaybar 20mm - non adjustable good for handling made a big diffrence!
Condition: Dirty has dust on it few months old
Price: $100
For Sale:R34GTT ISC "52MM" Alloy radiator These alloy radiators are a great upgrade if your looking to keep your engine cooler whilst driving at high rpm. The cooler your engine is the more power you will be able to run without causing pinging/detonation.
Condition: Its still pretty good has a few tiny bent fins! only used a couple of runs! basically brand new!!!!
price: $180
I will also Post anywhere in Australia or pick up
PM me for details
Also check out my Feedback :)
Edited by geraus
PM's Replied
Items: Remaining
For Sale: GTR ZTUNE fiberglass bonnet. Its fits perfect awesome quality.R34
3inch Dump pipe sold!
remaining:
3inch X-Force Full Exhaust system with 3inch Highflow Cat $300 - sounds micky!!!
remaining:
Dump pipe is back up for sale $200 comes with a FREE highflow cat 3inch
PMs replied
hey bud, im after the bonnet... is this bonnet gonna fit R34 GTT, do i need different hinges for it? plz txt me 0412373305( kelvin) if u still have the bonnet...im in melbourne btw.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
