Hey everyone.
Names Paul.
Currently own a 91 GTiR (which is for sale).
I have come here as i am afer a GTsT for my next car and wanting to learn.
I have been in the car scene since the late 90's so i am not your average noob.
I am very much a lurker. I read alot and dont say much.
What more to say.... Hi and here is my car.
Edited by big fat paulie
https://www.sau.com.au/forums/topic/360505-new-sydney-member-hi-all/
Welcome so sau mate.
You've probably already spotted the for sale section, and there's a "things to look for when buying a skyline" thread somewhere (might be in for sale, or gen maintenance, searching should find it pretty fast).
Hope you enjoy it here.
Welcome and there's always a few nice gts-t's for sale on this forum.
Liking your car and wheels too. I had the same set of wheels but in 18" for my v35 which i sold almost a year ago.
Question though...if you're selling to get something newer, i don't think a gts-t would be the way to go. Most gts-t's are quite old too and alot are still demanding-ish in terms of maintenance and replacing stuff.
Maybe a gt-t would be the answer?
I know i sometimes get sick of my 33 needing attention (but love it in the end haha).
Goodluck.
Thanks DIF
Thanks Touge. Yeah i love the wheels. I'd keep them if i could.
When i say "need something new" I mean as in I need a new toy. Dont really care about age of the car.
Thought about a GT-T but too pretty for me to drift.
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
