R34 Body Onto Gq Patrol Chassis/drivetrain With Rb26 Motor
I have had an idea buzzing around in my head for a custom build and I have some questions about feasability.
GQ Patrols have an RB30 motor (in some of them). I've seen some Patrols running an RB26 conversion for extra power which is a relatively straightforward conversion.
The Idea
I have often wondered about taking a LWB GQ Patrol chassis, shortening it by 305mm to match the wheelbase to an R34 GT-T 2 door, fitting an RB26 then modifying the R34 with a custom floor pan, matching body mounts to that of the GQ Patrol and bolting the two together. Retain the Patrol diffs, suspension, drivetrain etc and fit the R34's cooling system, engine management etc. A bit like taking the old Kingswood ute's and bolting them to a Range Rover chassis only with a Skyline/Patrol version.
I realise the project is
A. Impractical.
B. Costly
..............but most projects are :teehee:
What are the pitfalls? I can think of quite a few but keen on the SAU input.
FWIW no I'm not 12 years old with big dreams and a small budget
I dont think you will ever be able to engineer a cut and shut chassis, you had better speak to the engineer you plan to use first if you plan to road register it.
I believe they would have used the stock RB30 block, with forged internals then slapped the 26 head on it, as you need all the torque you can get to move the weight. I was planning to do my brother's patrol the same way.
took us 11 hours to swap an rb25det into the rb30 patrol and drive it away. drives fine and is going up hills in 3rd that used to require to drop back to 1st. rb25/30 would be even better, but that increases costs etc
as for the rest, that would be up to the engineer.
biggest hurdles i can see is wheel tubs, floor clearance to GQ handbrake setup (behind GB) and drive shaft, and the entry/exit angles if using the 34 body.
Thanks for all your ideas.
Adriano - The short wheelbase chassis is shorter than the 34 so would need lengthening. I could use the LWB chassis and lengthening the 34 body by 34 mm, but this would take away from the skyline's lines I think.
Scotty - Engineering a cut/shut chassis would be possible (as it is legal to build your own chassis if properly engineered) but it would need to be subjected to some pretty rigourous twisting tests to ensure safety.
XRATED - The Rhino buggies look cool.
Craved - I think a custom floor pan would solve the handbrake/driveshaft issues, and entry and exit angles would definitely be compromised using a skyline body, however with a body lift and some custom barwork I think it would be achievable.
What do you mean by the wheel arches presenting a problem?
Perhaps, it may depend where you are too.
My brother bought an ex ambulance f250 that had been professionally shortened after the rear axle (by the government), it took him over a year to get registered in Victoria, and only after hassling every engineer and Vicroads manager he could find. None of them wanted a bar of it. Chassis rails have to be one piece apparently. Ring and ask?
should make it easier Andrew, as you can cut the reinforced areas out without affecting the chassis strength
as to guard clearance, if you are going to run big tyres, and over alot of rough terrain the axles are going to move to some crazy angles. so unless the body lift as very noticable to may have issues with the tyres contacting the guards.
for example my r33 front guard openings are only 28 inchs wide. most 4WD's will run 33 inch tyres or similar
It all sounds nice but arent you worried about basics like engine oil trouble, patrol will go places an rb26 was never designed to travel across, I own both the cars you mention and I recon you would be dissapointed.
In the end you would have 2 throw away cars, unsellable.
An idea, have a search, I recently came across a bloke on a chat site, think he was in U.K. modifying rb26 single exh stainless manifold, to mate a big single to 4.2 patrol he had head semi assembled on bench inc man&turbo, like the man he's onto something.
And if I remember correcty he was going to make/mod more if anyone was interested
4.2 torque down low and buckets up top.
dont you have to update engines in cars not go backwards so what would it be patrol or skyline compliance hasells till the end of time, forget insurance.
and gq 4.2 don't run a cat std, so there's 1 problem gone.
engine mod not a whole car from scratch.
In the end you would have something you could sell,not what it cost but you'd have something special just the same.
and for a whole lot less than rb26, it would also be up and running in a 20th the time.
recon you should have a look around 4x4 chat sites to see what othes have achieved and go from there.
Heres another option save 50+% of the dollars your idea would cost, if your 32 is gtr, have a look at Nismo's lattest offering r34 6 speed conversion for 33 and 32gtrs About 11k ex japan, if I had the money!!!.
Edited by nobby
  • 3 weeks later...
  • 1 month later...
you can modify a cars chasis all you want. SO LONG as 40% is unmodified and original!!!!!
one of the guidelines we go by at the hotrod shop.
+1 we get patrols and landcruisers which have been converted into 4 door ute's with an extended chassis. It's more a case of being done correctly, fish plates and that jazz.
  • 5 months later...
i read a few yrs ago about a guy that put his commodore wagon shell on a patrol chassis running a holden 5litre. the whole thing was engineered and registered in NSW. i cant imagine using a r34 shell would make it any harder to engineer. it would be an interesting car to see. maybe to avoid cutting the chassis you could use a 4 door body???
yeah ive seen a few commo's like this too.
i doubt you will get around the chassis cutting thing. the old VW Manx's were shortened. and very popular. the only way to have one of those now is if it was an original one from way back when.
you can still build/buy them, but they are a full length chassis for these reasons.
go for it tho, this could look hilarious :) and very different :thumbsup:
I know the guy that owns this.... hell of alot of work.
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
