righto i bought this thing
so i have kept a few bits that i needed the rest is for sale
basically the followig parts are already gone:
interior, brembos, boot trim, dash,
however the following are still available
front brakes/ rotor and calipers $300
nismo 260km/h dash $280
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9034.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9045.jpg
3 gauge cluster $40
aircon $40( this is off another wreck obviosly)
complete inner front guards $30 each
17X9 gtr offset rays lightweight rims (very light) $800
two with minor gutter rash
245/45/17 Yokohama DNA E-spec rubber 90% tread
needs a wash but will do that when i pull them off
rear bar $170 includes tail lights
tail light $40 each
3.5 inch turbo back exhaust $350 cat back or $500 for turbo back included massive cat
cat back is stainless and in awesome nic, front pipe is tunned lenght hks (seen better days)
other things available, picks will come as i pull it off (the car that is)
boot with wing $150
doors $100 each good condition
gtr motor 2k for the long motor
gear box $600
abs $50
side skirts $100
everything behind the dash including wiring $300
rear wiring loom $200
centre console $40
door cards $50
front window $100
rear window $100
rear quarter windows $50 each
front seatbelts $20 each
brake master cylinder $40
clutch master and slave cylinder $100
steering column $100 including key locks
attessa pumps $50
A pillar trims $60 pair
rear trim $40 each(the part under the rear windows)
rear windscreen wiper $40
rear cut $300
have a rusty 3.5 inch exhaust $50 with cat
have a quiet 3 inch exhaust $150 perfect condition
all parts located in the lower blue mountains sydney
ask away
pete
0448468884
https://www.sau.com.au/forums/topic/360559-wrecking-r32-gtr-grey-sydney/
  • Replies 67
pete,
mark the rear wiper assy as sold. need it complete with every nut/bolt.
I'll drop the money in over the next day or two.
Hey mate I'll take the 3 gauge cluster how much for postage to 2113?
Can I get a pic of both the exhausts? The 2 cheap ones [email protected]
Cheers
Edited by stig mick
Hey mate, do u have the stereo surround?
and the right tail light?
How much to melbourne?
cheers
have two
a white one $30 + postage
the grey one is $40 cause i have to pull it off still + postage
postage about 20 bux
have two
Is the stereo surround white?Do you have a picture?Pls pm me
and with the right tail light, need the internals etc where the bulbs go. If its ok condition am interested.
Richard
Richard
No stereo surround mate
have a white and a grey tail light, as mentioned above. Includes the internals you need.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
