hey guys , after doing a bit of extensive reading lately on the forums about the rb25 neo engine and the thought of installing an aftermarket plenum , iv come to the idea of having the standard plenum modified to face forward . i was wondering what everyones opinions of this are ? as iv been reading there is a fair bit of modification needed , ie : custom aac valve plate , different 0 rings , a fair bit of movement as far as hoses go etc , TCS is in the way - would this be easy to remove without effecting anything ?. also on top of all this i had read one member stated that even with all this done , the car didnt run any good and he ended up returning it back to the standard setup.
now in saying this does anyone body know of , or recommend anybody in sydney to perform this?
will the car run accordingly if this modification is carried out correctly?
and finally what would this cost if anyone else has had this done?
any info would be greatly appreciated
https://www.sau.com.au/forums/topic/360594-plenum-modification/
Oh my...
What are you trying to achieve?
- Performance...? I can't see a performance gain. Infact all I can see is poor flow distrobution???
- Looks...? Looks waaay to ghetto fab to me, but I guys that's personal taste???
- Shorter pipe work..? well yes... but at what cost? I'll also add- I will garantee you would not be able to tell the differnence from driving the car on a back to back test!
Not to mention there are so many fantastic options for forward facing plennums- WHY BOTHER?
Cheers
Justin
thanks for your reply
i know in general there isnt any hp gain with this mod as iv read over and over , mainly just throttle responce. at the end of the day itd be good to have an engine without the cross over arm , thus making the car much neater and more easier to get around when working on it. shorter pipe work will be beneficial , besides i dont really want that huge amount of pipe running around over the fan and down to the intercooler like most cheap intercooler kits.
my main question of doing this was , if no body recons you get any more hp out of it , why bother buying somethng over $800+ to cut out 1 meter of pipe , i mean thats all it does , maybe increase flow ? no one ever notes how much more powerful their car has become of it ?
I wouldn't bother unless you're going to go whole hog either like I did so you've got a bigger area in the plenum and\or getting a bigger throttle body. It might be worth while if you got a bigger throttle body, or get two throttle bodies!
People used to do that plenum modification years ago when there were bugger all upgrade options for the RB25DET and Neo.
Nowadays there is absolutely no need to go down that route.
I love my Plazmaman plenum and the only thing I would swap it for is a Hypertune plenum (but they don't do them for RB25's off the shelf).
Ha ha... I kinda like it. Any more pictures?
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
    • @silviaz Ok cool, so much easier with a video. I can see why this video would be confusing for new players.   It is obvious that this entire bonnet is going to be resprayed, have a look in the background around 2:05, you can see a bunch of bare metal on the left side of the bonnet.  It's not an issue for the primer being laid down on the non-prepped clear on the bonnet. It will be sanded off at a later stage.  This might not be obvious to new players, but working on bare metal and factory paint in this instance, the factory paint is like a mountain and the bare metal is a huge valley. The bonnet needs to be levelled flat before it receives it's final stage of colour and clear coat. During this levelling process, the primer that is landing on the clear that you are worried about will be removed.  Also, this guy is out of control. Zero PPE while spraying, maybe he is a good example overall about what not to do lol.
    • Ok I FINALLY found a video lol. This took way longer than it should have as I could have sworn I saw multiple videos like this. I kept finding the completely opposite (the correct way of doing this). I wouldn't be surprised if I f**ked this up somehow.  I just realised where I've been getting confused and even with other things I work on. I haven't been doing things the regular way instead I'm going a roundabout way of doing things, like putting epoxy primer first then filler for example instead of putting just filler then primer on top of that, then wondering what happens if I get that primer on the clear coat that I haven't sanded yet. This was a bit of an epiphany 馃槀  But anyways, here this video. Time stamp, 2:56, some of the primer lands on the paint unscuffed above. You can see from the reflection it looks shiny.
    • It does, this part circled in red. I assume the OEM bolt might not work well with the poly bushing because the dimensions may be different?
    • The J arm doesn't have bushes either. Assuming that by "J arm" you mean the part of the upright that runs down from the upper arm's outer bushes to the top of the hub. That has a kingpin style bearing in it. If you meant the lower control arm, it has 1 bush, at its inner end. If you have PU in there, that is superior to Nismo rubber. If you meant the caster/tension rod - it has 1x bush at the front end, and again PU is superior to Nismo rubber. But as I said above, I would definitely get the GKTech arms for that, as sphericals slay all other options there.
