  • Replies 50
I haven't been to Wakefield yet. Keen as.
Week days are cheaper and I'm assuming less cars too ?
Do I need AASA club licence ?
Also what the skids? No pan there..
Same, If I'm not working, I'm there.
Cheers
1. Week days can have less cars, but sometimes a suprising amount of cars can rock up on a Thursday or a Friday
2. You will need a AASA or a CAMS licence. AASA can be bought on the day
3. Skids are what happen when you push your car to far and the only way to make it around the corner without coming off the track is to pitch it into a slide. Do this too many times (ie 4 laps in a row) and you will be black flagged. Get black flagged too many times and you will be asked to leave (I am told)
Who is running this track day?
It's a "Speed off the streets" day run by Wakefield itself ;)
I've got two extra spreets vouchers, my boss cant go so there up for grabs at $60 each.
According to the guy on the phone at Wakefield this includes the track day and also the AASA licence. As cheap as your going to get. Days left to use it are 19,20,25,27 and 28th of this month.
PM me if anyone is interested.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
