If you buy a genuine Walbro you should have no issues, it's the knock offs causing the confusion.
I have twin 255's intank and have been running them for years on e85 without a problem. These days I would go for the e85 416L version just for the sealed plug and the fact they are designed for long term ethanol use.
I wonder if my Nismo pump will last long term on ethanol. I haven't heard anything bad yet about the e85 walbro pumps so they must be a good upgrade from the standard pump.
Nismo over engineer their things, im sure they would have had race gases similar to E85 being tested with the pump during their their RnD. Im slapping mine in soon hope it lasts.
Since this discussion is ongoing...I'd like to pose a question...
How much power roughly do you think a single Sard 280LPH intank pump would support on a 2JZ?
I'm at 325rwkw atm on eflex but I'm thinking of turning the wick up alittle more...
"If you buy a genuine Walbro you should have no issues, it's the knock offs causing the confusion.
I have twin 255's intank and have been running them for years on e85 without a problem. These days I would go for the e85 416L version just for the sealed plug and the fact they are designed for long term ethanol use."
In regards to the Nismo pump, I'm running one on e85 with no problems at all. I stayed away from your standard Walbro pump just from the fact that they have a higher tendency to fail. I know a few guys who have had problems after a period of time.
I've heard this too. So i was never convinced the walbro were perfect little gems to begin with. Thats why I had no problems deciding to give This is the "fake" walbro pump a go as well
http://www.ebay.com.au/itm/GSS341-Type-340L-H-Performance-Fuel-Pump-Skyline-GTR-RB20-RB25-RB26-R32-R33-R34-/110983052442?pt=AU_Car_Parts_Accessories&hash=item19d71afc9a&_uhb=1
They claim 340L/PH. I"m not sure if anyone has verified it. I did get a genuine 255 too. Didn't notice any difference in the way the car ran between the two.
Anyway I will think about cleaning the injectors, or possibly buy another set for not much more than clean. Boost is staying low for now.
Can anyone extract any data out of the spark plugs?
Red spark plugs? hmmm.
Edited by sonicz
I would be curious to know as well. I will try and squeeze every kw out of my nismo pump before I need to move on :)
What's generally the limit i.e. maximum power for the nismo pumps?
RHD says 550ps and im sure it will get there and probably over.
regarding the walbro 450lph E85 fuel pumps....what power have people made with these and at what boost (psi)? have we found the limit of these pumps yet??
They are rated @ 450lph @ 0-30psi... A stock RB fuel rail runs a higher base pressure than that :whistling:
Once you get them to 60-70psi (which is what most people will be running), the flow drops to under 400lph, maybe even 360lph - I saw the rating graph from Walbro 450l a few weeks back but for the life of me i can't find it right now.
Gotta love the online retailers at the moment claiming they will support "900hp on a turbo set-up", maybe if you used two they would.
Haha exactly right
I'm running one getting 13.8volts, with my base pressure at 55psi and 26psi boost it made 410rwkw on e85,
Obviously lower and or stock rail pressure and lower boost will net more flow
I have been recommended by quite a few knowledgeable tuners recently to bump up my base pressure, (I am running 40 psi with the hose off) The bosch ev14's apparently spray a beautiful mist at 90-100psi but there aren't any intank pumps out there that flow much at such high pressures, certainly not the 255 twins I have currently.
To test my theory (more pressure = finer mist = better power and economy) I would need a large mechanical gear pump off the fuel cell, I am thinking one of these Magnafuel external pumps which are rated up to 120psi.
http://www.magnafuel.com.au/index.php/efimenu/efipumpsmenu/protunermenu
Might be time to ditch the twin intanks I think.
Yep injectors needed abit of help and also idles better so maybe the higher pressure is atomizing better?
My next step besides cams cos my stockers are holding me back would be 2000cc injectors and maybe a fuel lab external pump
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
