If you buy a genuine Walbro you should have no issues, it's the knock offs causing the confusion.
I have twin 255's intank and have been running them for years on e85 without a problem. These days I would go for the e85 416L version just for the sealed plug and the fact they are designed for long term ethanol use.
I wonder if my Nismo pump will last long term on ethanol. I haven't heard anything bad yet about the e85 walbro pumps so they must be a good upgrade from the standard pump.
Nismo over engineer their things, im sure they would have had race gases similar to E85 being tested with the pump during their their RnD. Im slapping mine in soon hope it lasts.
Since this discussion is ongoing...I'd like to pose a question...
How much power roughly do you think a single Sard 280LPH intank pump would support on a 2JZ?
I'm at 325rwkw atm on eflex but I'm thinking of turning the wick up alittle more...
"If you buy a genuine Walbro you should have no issues, it's the knock offs causing the confusion.
I have twin 255's intank and have been running them for years on e85 without a problem. These days I would go for the e85 416L version just for the sealed plug and the fact they are designed for long term ethanol use."
In regards to the Nismo pump, I'm running one on e85 with no problems at all. I stayed away from your standard Walbro pump just from the fact that they have a higher tendency to fail. I know a few guys who have had problems after a period of time.
I've heard this too. So i was never convinced the walbro were perfect little gems to begin with. Thats why I had no problems deciding to give This is the "fake" walbro pump a go as well
http://www.ebay.com.au/itm/GSS341-Type-340L-H-Performance-Fuel-Pump-Skyline-GTR-RB20-RB25-RB26-R32-R33-R34-/110983052442?pt=AU_Car_Parts_Accessories&hash=item19d71afc9a&_uhb=1
They claim 340L/PH. I"m not sure if anyone has verified it. I did get a genuine 255 too. Didn't notice any difference in the way the car ran between the two.
Anyway I will think about cleaning the injectors, or possibly buy another set for not much more than clean. Boost is staying low for now.
Can anyone extract any data out of the spark plugs?
Red spark plugs? hmmm.
Edited by sonicz
I would be curious to know as well. I will try and squeeze every kw out of my nismo pump before I need to move on :)
What's generally the limit i.e. maximum power for the nismo pumps?
RHD says 550ps and im sure it will get there and probably over.
regarding the walbro 450lph E85 fuel pumps....what power have people made with these and at what boost (psi)? have we found the limit of these pumps yet??
They are rated @ 450lph @ 0-30psi... A stock RB fuel rail runs a higher base pressure than that :whistling:
Once you get them to 60-70psi (which is what most people will be running), the flow drops to under 400lph, maybe even 360lph - I saw the rating graph from Walbro 450l a few weeks back but for the life of me i can't find it right now.
Gotta love the online retailers at the moment claiming they will support "900hp on a turbo set-up", maybe if you used two they would.
Haha exactly right
I'm running one getting 13.8volts, with my base pressure at 55psi and 26psi boost it made 410rwkw on e85,
Obviously lower and or stock rail pressure and lower boost will net more flow
I have been recommended by quite a few knowledgeable tuners recently to bump up my base pressure, (I am running 40 psi with the hose off) The bosch ev14's apparently spray a beautiful mist at 90-100psi but there aren't any intank pumps out there that flow much at such high pressures, certainly not the 255 twins I have currently.
To test my theory (more pressure = finer mist = better power and economy) I would need a large mechanical gear pump off the fuel cell, I am thinking one of these Magnafuel external pumps which are rated up to 120psi.
http://www.magnafuel.com.au/index.php/efimenu/efipumpsmenu/protunermenu
Might be time to ditch the twin intanks I think.
Yep injectors needed abit of help and also idles better so maybe the higher pressure is atomizing better?
My next step besides cams cos my stockers are holding me back would be 2000cc injectors and maybe a fuel lab external pump
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
