  • 5 months later...
Thread bumpity bump!
So I finally got my car back on the road...standard intank pump and my tuner strongly suggested I keep the surge tank with 044 so I did (for the reason that I'm making 430kw on e60).
Has anyone since seen results of a pierburg pump on e85? Probably I can answer this myself as I think I've exceeded this option with the power I'm making + I will eventually run e85 which means I will need more flow.
Surprisingly though, the 044 held up to the task on e60 but it's close to its limit hence there will be no room for e85.
The question did arise 'what if your pump starts to deteriorate?' Not a good scenario, dangerous.
So it's 2 options for me, either add another 044 in parallel to the surge tank OR replace the 044 with a new 044 and see if that makes a difference as possibly the current 044 is not performing at its optimal peak but again, I don't think this is the case purely because of the power it's currently supporting.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
