It's says 12mm bungs to allow various configs,
What size are most fittings/lines people using?
I'm sure it could be modified to suit bigger.
You'd need two if you were going serious e85 power, but then youd probably just have a conventional surge setup anyway,
Even two would be still quite manageable and neat I'd think though.
Edited by jangles
stumbled across this. VW/audi world
is ~4 diameter, ~8.5" long
http://www.034motors...nk-p-21527.html
great find and would be such a nice setup. Is 1litre enough though?
I remember talking to Robbie ward about this and his recommendation was a 3litre surge tank?
Read the info!!
Factory feed and return to tank,
Pump to rail, rail to surge.
How long would it take to completely empty 1l with an 044, plus 2m of line, with nothing returning to the surge?
It's designed for far smaller cars, but, It would be a far better option than just installing a pump by itself. It is never uncovered until zero fuel. 2xpumps paralleled would make it a 2l surge,
Dash 6 is the most common, dash 8 for some i think.
It's a well thought out little device, but yes as you said if you're E85 you'd have 2 pumps and a larger tank anyway.
This would suit anyone IMO who's on either E85 or pump fuel and around 350kw because they just dont need that extra pump.
Very good find!
Well depends on voltage and how wide the ID of the line is, but you'd be able to have a safe guesstimate of about 30 seconds based on 300lph and a big line ID (enough for 1.5L).
Are the surge tanks really nessesary, 2 nights ago I throught to myself I'm going to put a end to all this talk about surge tanks and test my setup.
Got some decent windy roads around my way, they all private of coarse.... So my tank was low, like the light was on and the needle only just on the E white line.
And I was into it, throwing it into the corners, coming out of them sideways foot flat, up too 140+ and back down to 40 around some of the bends...... Not 1 drop of surge, nothing it was like I had a full tank of fuel..... This is 330kw -5's on 98, but still it was a low tank.
I don't see the need for a surge tank in a street/track car.... And for a track car, just go buy a fuel cell.....
Keep it simple guys, less sht goes wrong.
I mean on the track you would make sure you have over 1/2 a tank in the car before each session, it's really not a hard thing to do, and 100% you'll have no issues....
  • 9 months later...
Old thread bump here haha but I have my pierburg still not installed...I'm going to take the plunge and remove my surge tank with 044 and run this damn pump on its own, submerged in tank.
I kinda feel like I'm going backwards by removing my surge tank with 044 but I don't think I need this setup for ~350kw
Pierburg pumps are good, they are the only pumps that can pull fuel up a hose, which is why I use one as a fuel transfer pump for draining tanks.
A surge tank is not related to a particular power, it's how you drive, hard cornering and drag launches on less than half tank that require engine protection against fuel surge. I would leave the 044 setup unless you putt around town.
You said it yourself mate, you're going backwards. It's in there, it works, leave what isn't broken, alone!!!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
