Drift Gauges with AFR, Boost & Oil Pressure comes with all wiring, sensors and fittings $120
Stagea M35 wheels 17x7 +40 tyres are worn out on outside edge good for skids. $150
https://www.sau.com.au/forums/topic/360634-garage-cleanout/
R33 parts
Turbo heat sheild $20
Wiper & Indicator stalk $50
Wiper Motor $40
Handbrake $40
ABS unit $100
SRS Steering whell clock $50
SRS airbag ECU $50
SRS airbag passenger $120
Power steering unit $100
Stock dump pipe $15
Aircon fan $60
Radiator fan with hub $100
intercooler pipe $20
Series 2 dash $70
cluster surround $40
glovebox $40
Steering coloum bottom cover $20
Aircon condensor $70
R33 GTR V spec Aircon condensor $70
R33 series 3 GTR steering wheel red stitching $200
R33 boost solenoid $50
2 X wiper amplifiers $20 each.
Can pick up near Golden Grove in SA or I can post
PM me or Brad 0427999093
https://www.sau.com.au/forums/topic/360634-garage-cleanout/#findComment-5757221
R the gauges in working order. What's the best price you can do with postage to melb 3021
Yes the gauges worked before I took them out. How about I include postage in the price?
https://www.sau.com.au/forums/topic/360634-garage-cleanout/#findComment-5759594
will that s2/3 cluster surround fit/bolt straight into a s1 r33 gtr? same with that r33 gtr s3 steering wheel?
I know the cluster surround will fit and the steering wheel would have the same slpine. I dont know if being an airbag wheel if it had more under the base. But looking at the S1 S2 steering colums with the stalks they all look the same to me.
https://www.sau.com.au/forums/topic/360634-garage-cleanout/#findComment-5767620
  • 3 weeks later...
Hey Brad,
Is the "Series 2 dash $70" still available?
Yes Abe and its in really good condition.
real keen on the srs clock spring, how much with postage to cooma nsw 2630?
cheers
Yeah I can post it for $60 inc postage
Gauges still avalible??
Yes I can post them to you for free
https://www.sau.com.au/forums/topic/360634-garage-cleanout/#findComment-5841615
    • Hey VQ Member,   The FB Infiniti group wants to arrange a meet Sydney meet up, are there any members in the Sydney area who like to meet up. Let me know what you think ppl.
    • The small boxes will wear out the input shaft bearings.....if and only if you seriously exceed the torque input that they were designed to handle. It is very common for them to give up after a few years behind bosted RB20s and if you put a 25 turbo in front of them they can't last forever. Behind an NA RB20? Should last forever and ever and ever and ever. If it has died, it is from some sort of mistreatment, or perhaps extremely bad luck.
    • I’m going Barra fishing with my mate this weekend coming so I could probably stop in at yours on the way back home maybe Sunday arvo or Monday morning.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
