The time has come for me to sell my beloved r33. I've owned this car for over 3 years now however I've just bought something else so she must go. All servicing and maintenance on the car has been done by Daniel at Elite Racing Developments aka the skyline specialist. This car has been my daily ride so the way I've set it up is a perfect compromise of handling, power and looks. I'm extremely fussy with my car's, therefore it's been thoroughly maintained and not thrashed. Looking for a straight sale so definitely no swaps as I have no need for another car. Full details as per below. Any questions, feel free to send us a PM. Cheers.
Odometre: 98,000 kilometres
Exterior:
· Top secret front bar
· GTR side skirts
· GTR rear spoiler
· GTR grill with badge backing removed
· HID's headlights
· Nismo smoked indicators
· Gmax 18inch deep dish wheels
· 3M carbon fibre vinyl A pillars
Mechanical:
· Full exhaust with custom dump pipe
· Whiteline heavy duty 24mm adjustable swaybars (both front and rear)
· Turbotech boost controller set to 11psi
· Front mount intercooler including piping
· Go Fast Bits BOV with custom plumb back
· K&N pod filter with custom shielding
· Walbro 500hp internal fuel pump
· Splitfire coil packs
· Bosch platinum spark plugs
· NPC heavy duty clutch (capable for 300rwkws)
· Motul gearbox oil
· Motul brake fluid
· Always serviced with motul full synthetic oil
· Already had the 100,000km service (gates timing belt, tensioners, water pump and all seals)
· Replaced the rocker cover gasket
· Power steering fluid flushed recently
· Brand new Nissan radiator put in over a year ago
Interior:
· Momo millenium steering wheel
· Greddy gear knob
· 3M Carbon fibre vinyl layered dash
· Italian leather gear shift and handbrake boots
$10,000
Located Sunnybank Hills, Brisbane
https://www.sau.com.au/forums/topic/360636-fs-1994-nissan-skyline-r33-gtst/
  • 3 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
