I contacted JustJap and got a price of $220 for a brand new cowling plastic with the rubber strip attached, you cant actually get the rubber strip by itself...
I asked if there would be any discount if we could place a bulk order and they said they would see what they could work out depending on numbers.
Of course Im still tempted to see PSI parts would want to make these in CF, I have a local rubber supplier searching for a similar or the same profile rubber strip to replace the OEM nissan one,
I should hear back in the next couple of days about the rubber strip material or similar being able to be sourced...
Anyone interested in a new cowling, a CF version or new rubber strip?
group buy on one of these options?
https://www.sau.com.au/forums/topic/360667-brand-new-cowling-with-rubber-strip/
are you talking about the rubber strip that runs across the bottom of the windscreen? if so, i'm interested to know how much a replacement is.
edit: someone told me once that clarks rubber sell a similar profile strip. i went to one of their stores. they were pretty dumb. i never got the rubber :/
Edited by Munkyb0y
yep thats the one, Ive got a rubber supplier searching for it for me... see what he finds, then I'll just paint the plastic...
but Im also keen to collect more CF so getting some made up would be completely awesome, and PSI parts carbon work on the foglight surrounds was excellent...
PSI is also keen to make up some CF front fenders depending on numbers....
so are people keen for a whole new cowling or just the rubber strip to be replaced, you do realise the rubber strip will need to be glued on somehow, thats how it was from factory
Im not sure what the profile or size of the r34 one is but it would be great if they are the same...
Im hoping I get a phoen call saying he has found a match for me then we can buy a roll of it...
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
