Hey guys
I got supercat cannon on my R33 Series 2 rb25det,
Its so loud sometimes even on the highway and Im hearing impaired too still loud for me!
Im running 3inch from turbo with hotdog to cannon
Whats best way should i do? proper cannon? highflow muffler?
I just get too much attention with the exhaust so loud
Ive looked on google too seems not the right answer for me
Thanks
Matt
Edited by debmatt09
https://www.sau.com.au/forums/topic/360677-high-flow-muffler-or-cannon/
ahhh is that what makes it loud too? it came with the car when i first brought it
That config will bring you to around 87-90dB in most cases in 3".
Gotta be straight through for best performance and also as big as possible.
So basically the smaller you go from the "biggest possible", the louder things will get.
Either way a hotdog + cannon is doing you no favours. You might find just a single rear muffler might fix your issue.
Everyone is different when it comes to "how loud" something is so i just refer it back to "legal" which is 89dB in Vic in terms of a point of reference.
If you want quiet without the excess noise look for something stamped JASMA
I had a 3.5 inch exhaust on my car with no mid muffler and a JASMA rear muffler it was sooo quiet I had to change it you could barley tell the car was on, it weighed a ton though
i just have a single 3" muffler on the back of my rb26.. sooo quiet its ridiculous, they call it a centre to centre muffler (regarding the IN/OUT positions). the path is straight thru which i guess is good for maintaining performance. any exhaust shop will stock the one i have, then just put a nice shiny tip on the end, and your flying incognito again.
ditched the cannon a while ago, but will be returning to it with no cat for WTAC only
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
