R33 Rb25Det Clutches, Exedy Hd, Nkk
Hey guys,
Ive got two clutches here for sale. Both removed from an R33 GTST prematurely(one written off, the other for a 5 puk clutch upgrade). Both still are quite healthy. The exedy was holding 230rwkw just fine, has a modified Nissan pressure plate which has just a slight heavier pedal feel. The other has some other kind of pressure plate, felt pretty standard.
Both clutches are as I said earlier, healthy looking.
I have no idea what they are worth so lets just put up a price of $200 each with pressure plate. I can get photos of the clutches if you guys are interested!
I also have a standard flywheel which came off with the NKK clutch so it would be best coupled with that. I still would suggest a fresh resurface. I got mine done for $20.
PM me guys. Clutches located in Sydney.
Attached pix of the clutches Ive got.
The 4 spring center is the Exedy clutch, the other with the smaller spring center is the NKK. You can tell from the surface of the NKK that it has hardly been used. The clutch surfaces are still being worn in, made flat. Will pull out the caliper and measure the thickness of both clutches. Judging by the pix they still look healthy.
 Share
