Hi guys,
I have decided to remove my Trust/Grex brake kit (6 pot front, 4 pot rears)and OS Giken gearbox (gears 1-5) in order to sell my R33 gtst at a much lower price.
The brakes are currently still on my R33 gtst and will come with everything thats needed to fit on a similar car ( not sure how diff GTR's are ). Front rotors were replaced about 3 months ago along with new front and rear Bendix pads. Has not been tracked. Asking $4,500.
OS Giken box with gears 1-5. Asking $4000.
Everything is still on the car atm. Inspections are welcome as i want to make sure the buyer can see/feel everything is working 100% for him/herself before i go removing them.
Cheers Kev.
sorry these are the only pics i have atm but will get some with the wheels off.
Kev,
can you post or PM me some more info on the gear box please, is it straight cut? does it retain the std sincros and what centre plate does it have.
Cheers,
Ryan
Heya Ryan,
The gears are not straight cut and yes they still use standard synchros ( replaced with new ones when box was built )have no idea what sandwhich plate was put in lol.
Regards,
Kev
  • 4 months later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
