This is Vinh’s skyline
Bought thiscar off a mature owner, was manual and meticulously looked after, then Iproceeded to do a manual conversion, obtain rwc and register it since then Ihave done the following mods, there have been no stupid cutting in holes ofbattery trays or any other modifications to body
1993 r32 gtstTYPE M SUNROOF last of the r32 model
gtr fiberglass front bar
bosch 040 fuel pump
rb25 turbo no shaft play in good condition, givesit a bit more kick
blitz return flow intercooler
car is legal no holes in battery tray, nostupid modifications and hacking of anything
hi cas lock bar, all lines taken out, sodeleted hicas EVERYTHING including motors
type m skirts and pods
r32 gtst wheels with good tread
cusco zero 1 coilovers on the front, no knocks orleaks in good condition
koni shocks and springs in the back
front strut brace
3a racing pod filter, brand new
replaced newair flow metre
gates timingbelt re done, runs perfect now
comes withboost gauge just not wired up because running stock boost
exedy heavy duty clutch and pressure plate (5speed manual)
alpine head unit with usb plug in and aux
all electrics work
3 inch TURBO BACK with de cat, and has a singlerear pipe at the back
car is still registered can come with or without12 months reg
no rwc
interior in good condition no cracks on dash andvents in perfect condition
upgraded castor rods with aftermarket bushes(nonthanlane)
viscous diff
sunroof (93 model, late model)
thats all i can think of at the moment let me knowif your keen mate im looking at 7.5 grand (spent more than that on mods alone),make an offer but
<br style="mso-special-character:line-break"><br style="mso-special-character:line-break">
heres pictures, car hasfaded paint but i have rubbed it down and i was going to respray it, has beenprepped and coated for respray, rubbed it down and quickly put a coat over itso i can drive on the street
also forgot to mentionthis is a type m r32 1993 sunroof, last of the r32 was owned by a mature ladybefore me (was an auto but i converted it) also the car has no stupid batteryholes or any other cutting of anything as i like to keep my car legal
wheels dont come withthe car because someone decided to steal them will come with r32 gtst wheelswith rubber, also the number plate it is registered with was stolen, new numberplates are [YAQ 483]
any questions just askor call 0413 926 794
  • 3 weeks later...
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
