Ive always wanted to replace the orange plastic indicator lenses on my front bar of my series 2 with the same lense as the driving light uses, its been done using plastic of different sorts but I want to use the glass ones so it looks the same...
I have some spare glass lenses, but they need to be cut down to fit, all of the glaziers and glass artsits Ive shown them to cant or wont attempt to cut it... so the only thing I can think of to get this done was to use a diamond hole saw Ive searched for a while to see if someone has use these on headlight lenses fearing that I would just end up breaking the glass, but it seems it may be possible, I found a thread where they were modifying BMW headlights to use with projector install.
so Im gonna have a go at this, Ive already sourced the diamond hole saw, the guy below is basically using the exact same method I was going to use, so it atleast seems Im on the right track...
If anyone has any tips or advice please let us know...
if it works out well I may have a diamond hole saw for sale barely used and the right size so others can do this mod as well...
5C) Attach the diamond-plated hole saw and set the drill to its slowest speed. The recommended speed is about 160 to 180 RPM. We achieved a good result despite the drill press’s minimum speed of 250 RPM.
2.75” or 70 mm diameter hole saw to cut glass
5D) Build a jig with wood scraps to secure the inner lens. Position two wood blocks so they fit into the notches of the lens and screw them down into the wood base. Lens goes face down so it can hold water.
5E) Move the hole saw down to position where your hole will be cut. Clamp the whole assembly onto the drill press when you’re satisfied with the positioning.
Drill press setup
5F) Fill the lens with water before you drill. However, the hole saw manufacturer recommends using a diamond tool coolant. I found water worked just fine. Either way, the water or coolant is absolutely necessary to:
– Cool the hole saw
– Lubricate the cutting surface
– Suspend glass dust
Fill her up
5G) Start drilling and use as little pressure as possible. Have patience because it will take a couple of minutes to go through each piece of glass. IIRC, the recommended pressure at the cutting surface is 2 lbs. Let the drill do the work and every so often, raise the hole saw to let water settle. Once you hit the wood base, lift up and shut off the drill.
Glass drilling – click to play (2.33 MB AVI clip)
White liquid is water mixed with glass dust
The center piece – remove it before you do the next one (we neglected to do so after the first one)
5H) Remove the lens and rinse. Smooth down the cut edge with waterproof sandpaper under lukewarm running water. Repeat for the other lens.
5J) Put the lens back into the housing glass and apply black silicone to hold it in place. The two tabs hold it in place but it could rattle so the silicone is strongly recommended. It’s also a good fix in case one of the tabs is broken which is circled in red below.
Silicone the sides only
I did some searching a while back when I read Phil's original thread about attempting this and came across these pics on JDM Styling (I think), forgot i had them on my phone.
Just goes to show it can and has been done on a S2. After the glass cutting is done does anyone know what kind of bulbs can be used? as in if a big orange bulb is put behind the clear will it just look orange again or will it be far enough back to not stand out?
Philips make a "silver vision" indicator bulb. Whole thing is silver but flashes organge, that's what I was planning on using.
The only problem I can see is with them, they are cutting the hole on a flat surface. Because our glass curves at the edges, you have to cut on this edge. Not to sure how that will go.
It's a pain in the ass to cut. So annoying that a glass place won't do it. I wouldn't even care if they gave it a shot and if it smashed, it smashed. The fact every one just says "it can't be cut" pisses me off.
  • Like 1
Dale how bout psi parts make the whole thing? It's not like your busy with other stuff or anything hahahaha
Forgive my ignorance I've never had a standard bar on my car. But how different are the two lenses (indicator and parker) in size or shape?
As we could probably do this in plastic without too much trouble.
I can't see why a plastic lense wouldn't work, you would have to get the "pattern" or lines or whatever you want to call it though as I think it would look a bit funny and cheap with just a flat clear piece of plastic/perspex there.
Maybe one of us should donate a set to psi parts so they can see what they can come up with? Dunno how much a second set is worth though???? If cheap enough I'm willing to send them a set, anyone know how much they go for?
thats pepsinators car here in adelaide, theyre not actually tinted, he did that in photoshop
I thought the dullness to the indicator side was because the reflector isnt as shiny and bright as in the driving light.... I wonder if I can fit the reflector into the indicator side as well so they look the same...
OK, so I did a little reading on the difference between the two lights and what I'm thinking is that we could possibly use the original orange cover and re-produce this in the exact same size/shape/pattern but in a clear plastic (blow molded). I'm unsure how close we can get to the glass finish, but fitting would be like OEM as we would have it CNC'ed just like we have our clear cam covers done. I thought about doing the fog light in the same process (to keep both identical) but from what I've seen it will get pretty messy removing the glass, which has to be heated to soften the glue.
Is this something that you guys would want, or do you prefer the glass option?
IMO I don't think it has to be glass, as I imagine a glass lens would be a lot more expensive to reproduce??? But I can't speak for the other guys
But as I said above it would have to have the pattern to it and not just flat clear plastic as it would just look as though a piece of Perspex was thrown in there.
Also as 75coupe said it my be worth investigating how to get the reflector part in there behind the lense so they both look the same.
I am due to go to a skyline wreckers in the next week or so for a couple of little parts and I am happy to donate a set if I can get them. PM me if you are interested Dale.
Yeah the pattern will be exactly the same as the orange one. I'm keen to get a hold of the orange lens and the surrounding bracket to look at mounting, only then will I be able to determine the manufacturing requirements and projected costs vs. batch size.
I think plastic would be fine as long as it looks close enough to the glass. Doesn't have to be identical, but as long as from a bit of a distance it looks the same.
I literally through the orange lenses out the other day lol.
I have a spare orange lense that will be thrown away if you need it Dale....
Im still keen to see if I can cut down the glass lense and use the same reflector since Ive have all the parts...
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
