Im planning to do an engine coversion, R33 rb26dett engine with rb25det gear box into a s14 200sx.
Im planning to do the conversion myself, is there anything you guys think i should know?
Has anyone done this conversion?
Which engine cross member could i use or do i have to get it fabricated?
And also same question as above for the gear box cross member?
Does the gear box bolt straight up?
Thank for the help.
https://www.sau.com.au/forums/topic/36081-rb26-s14/
Hi Sooky, try the Silvia forums, this stuff is done and talked about all the time there.
From what I have seen you use a Cefiro front cross member as they are a Slivia platform that came standard with an RB20. So the cross member is designed to fit a RB into that chassis. The SR20 gearbox doesn't bolt up and it wouldn't handle the torque anyway. The conversions I have seen use an RB25DET (as in R33 GTST) gearbox with a spacer to bolt up the standard rear (gearbox) cross member.
Hope that points you in the right direction.
https://www.sau.com.au/forums/topic/36081-rb26-s14/#findComment-721260
thanks for the replys,
so i can use the rb25 gearbox mount with rb25 gearbox cool.
then seems the only major part to get fabricated will be the driveshaft
http://www.mckinneymotorsports.com/sale.php
this is one of the company in the US. thta had made a motor month kit for the car. i am unsure if this would work for you. but it has customdrive shaft to fit and everything.
do you guys have a KA engine or a ca18 or sr20??
cause we used the crossmember for the KA engine with the swap.
https://www.sau.com.au/forums/topic/36081-rb26-s14/#findComment-721878
I am going to be swapping in a Rb25DET into my S14 and McKinney seems to be the only one right now who has a RB26 mount kit. Their kit lets you keep both turbos.
Get the driveshaft custom made at a local shop. The KA X-member should be fine if you get their mounts.
there are a few other. i am waiting to hear about then before i think about using them if i do a similar swap.
now i am wondering if austria ues a KA similar cross member if they aren't. then this kit would be useless.
https://www.sau.com.au/forums/topic/36081-rb26-s14/#findComment-721947
R32 crossmember
Modify the gearbox crossmember
Modify the tunnel to fit the g/box as it is much chunkier than the SR box
modified tailshaft
plus some more little things once you actually get it in there.
I hope you know what you are doing when it comes to cars and have alot of $$$ & time if you want to do it properly.
https://www.sau.com.au/forums/topic/36081-rb26-s14/#findComment-724617
Hi guys, I have no idea why people do this conversion. By the time you stick an RB into an S14 instead of the SR20DET it weighs more than an R32 GTST. I have weighed a couple and they came in over 1350 kgs, our R32 GTST with an RB31DET weighs 1245 kgs. Even an S13 is really not worth the effort.
In the US where they don't have SR20DET's I can understand it, but in Oz and NZ it baffles me.
https://www.sau.com.au/forums/topic/36081-rb26-s14/#findComment-725340
Its called someone who wants copious amounts of power.. think about it, you go and spend your $30k on a bullet proof SR20DET, effectively your pushing it pretty hard to make 400rwkw and i dont care who has tuned it, you still have a time bomb on your hands. first car that coes to mind is DVLISH..... It either blows up or its only a matter of time before it get tired and needs a rebuild....
so instead you throw your $30k at an RB26 build and effectively have the pottential for 330rwkw with bolt ons...... ad some forgies, a nice set of rods and should have closer to 400rwkw. Take it to the next step and the possibilities are endless.
Now before you go telling me that the power as to be gotten to the ground, yes i already know this. Anyone that has been crazy enough to throw $25k at an RB26 S14 is not silly enough to leave standard suspension or the standard braking system..... its going to take some time and effort to sort it out but its time and effort that gets people the numbers in the end.
As for weight....i think the extra 100kgs will benefit the car in the long run anyway. According to the weigh bridge, my S14a weighed in at 1260 with half a tank of fuel and a stereo when the SR was fitted. Most of the weight added is in the gearbox anyway and its more central than front heavy. Doing these things right takes time, and time i have so its going to be quite interesting to see how she goes when back on the road.
can i ask how many RB26 S14's you have weighed Sydneykid??? as i know of no other S14 with an RB so far and am interested to see who else has done this conversion
https://www.sau.com.au/forums/topic/36081-rb26-s14/#findComment-725786
Because Sr's are crap :rofl:
PHaT MR30, pics of your conversion please.
https://www.sau.com.au/forums/topic/36081-rb26-s14/#findComment-726734
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
