My car currently runs with no o2 sensor connected as the one on there is a wide band sensor that was used with a FCON that was on my car but removed by previous owner. If I connect it the car runs like a dog. My car is rare and old and finding parts is sometimes a challenge. I want to get the ecu chipped and was told it wont work with the wide band sensor. I have the nissan part number but nissan AUS dont stock it. What are my other options of obtaining one and more importantly is there some sort of universal o2 sensor I can buy that will do the same job? I was told I need the original one as its values are set accordingly for my car but it looks like that is not an option. I contacted petroject but they cant help. Are there any universal sensors that will work for me? I am itching to get my car tuned.
https://www.sau.com.au/forums/topic/36084-universal-o2-sensor/
There's a Ford one (EF Falcon?). Talk to Steve @ Speed Technology in Mitcham 9873 5400 to confirm.
Also, I expect any of the modern Nissan ones will fit the hole in the exhaust (but the Ford one is cheaper).
I understand I can get one to fit the hole but I was told they are all calibrated differently which will have adverse affects if I have the wrong one. Is this correct? I dont just wanna get anything that fits in, I want to know beforehand that it will work sufficiently.
All the O2 sensor is is a ceramic material that alters its output voltage depending on how much O2 is in the exhaust gas. It has a rapid change in output around the stoichiometric point (AFR = 14.7:1). They all have a range of 0 - 1V, AFAIK.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
