Hey Guyz,
This afternoon i had a weird problem with my tacho. When i turned on the ignition to the ON position, the tacho meter started fluctuating up and Down. Withouth even starting the engine. I Switched off and on again and the problem went away.
Anyways, when driving in the city the problem came back and this time even when driving. when i was driving normal at about 2500RPM it was showing about 5000RPM.
Has anyone experienced this? Any help will be appreciated.
I recorded a bit of it while parked. Engine OFF.
video here - http://www.youtube.com/watch?v=xQWx1lAMgF8
https://www.sau.com.au/forums/topic/360840-weird-tacho-problem-need-help/
Ive got that problem atm :S
Only thing I can think of is possibly a loose or faulty wire somewhere.... maybe? Ive pulled out the cluster and tacho and completely pulled it apart looking for a bad solder or loose wiring but found nothing, have given the dash a hit which fixed it momentarily. lol
But it has slowly started happening more often for me :S
Other note... I have PFC with controller and it always shows the correct engine revs, even when the taco is going crazy. So for me its either the cluster itself or a wire between the ECU and cluster. I was going to buy a new cluster but I'm sure I read of someone with the same problem and a new cluster didn't fix it. I haven't been bothered to look at wiring as yet though, Anyway - I'd say its either bad wiring or the cluster. good luck.
Thanx for the reply mate.
Going overseas tomorrow so wont be tryin to fix it untill i get back.
I am planning to open up everything and see if somethings loose. I tapped it too and it worked fine for a while.
Will update here if i fix it.
Cheers,
Vish.
Hey man, I'm with you, with the same problem... But b4 buying a new cluster borrow one off someone to make sure it is the cluster....
This looks like a common problem these days :(
