  • Replies 45
Posted Images
Just buy an RB25DE and get it swapped in. You'll probably need the exhaust as well.. chat to someone like unigroup engineering, they can go through everything with you.
you'll need wiring loom etc. as well.
Keep the gearbox though... gtst gearboxes are solid.
Edited by SKITTLES
I you just take the turbo out and replace exhaust manifold with a non turbo one and replace where ever ur intake plumbing with just a pipe going to ur airbox you could do that. But don't you will end up with an engine with less power than a non turbo engine since the lower compression ratio. just swap in a new engine and sell ur old turbo one you might even make a a bit of money if you sell the turbo engine.
buy a non turbo R33 then
it's gonna cot you more than its worth to change the engine
It is really hard to find a skyline without a turbo, that is why i was thinking about buying one and taking out the turbo. But i think i might keep looking if it'll cost more
sounds like that could cost more than i would pay for the car, i would be better of to keep looking for a skyline that doesn't have a turbo
Not to mention that, unless you have a fetish for non turbo RB engines (if so. get help), a turbo car with non tubro engine is still a turbo car as far as the laws is concerned. So yes, keep looking for a non turbo one.
That being said, if you found a non turbo car that had been converted to a turbo one, you could legally remove the turbo and put normal minfolds back on and drive it legall, as far as i can tell.
thanks will keep that in mind.
It not hard at all to find a non turbo skyline. R31s are almost 95% non turbo, there are also heaps of non turbo r34's for around the price of a turbo r33, i see them all the time on carsales.
Seriously if you are on your p's dont bother owning anything to expensive, just buy a old rwd corolla or something and learn how to drive before you spend a fair bit of money on a car.
I did my p's in a ae86 and it was the best thing i ever did, didn't care/matter if i had a minor stack, cheap to run and insure.
If your not on your p's then siff want a non turbo skyline :teehee:.
thanks for that bit of info, will try looking harder for a non turbo skyline. Should be able to find one. Am thinking about waiting til i'm off my p's but i can't help myself but want one already
I'm going to start counting from now on how often this shit gets asked on here.
I will assume you are on your P plates and therefore can not drive a turbocharged vehicle. Buying a turbocharged car and taking a turbo off does not change a thing. The car was still complianced and registered as a turbocharged car. Therefore it is still illegal for you to drive! Why don't you people ever understand this, it is not that hard to understand!
+1 AND P platers cant drive modified cars. Removing a turbo IS a modification!
Only prob with almost all the r34 non turbo models is 95% are friggin auto's. They are cheap though, around 8k.
Seriously save your coin and just wait till your of your p's, you can go nuts then.
yer i'm finding that out too. I will just wait til i'm off my p's will be much easier to get a car when i'm off them
NA 33's aren't all that hard to find. I picked mine up off carsales for 3k with 6 months rego and some minor issues.
Quick look on carsales just now has shown me at least 5 within the first couple of pages.
thanks, am looking up some in car sales at the moment and am able to find some good cars without a turbo
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
