  • Replies 85
So I looked up threaded sleeves for like half an hour and it seems the smallest difference they come in is 4mm. Which makes sense, 2mm is not much room to work with.
Anyway, I sent an email to the company in Germany to see if they could make them in 10mm if we did a group buy. At the end of the day I don't see why it would be a problem for them to make them in 10mm, so we will see what they say.
Will let you guys know.
Also I found out a few of the Nismo gear knobs actually have a 12mm and 10mm hole in them so they fit both shafts, perhaps this was the confusion with some people mentioning a 12mm shaft in a R33.
I wouldn't mind one if it was made in black aluminium, like my Nismo one :D
And as for you Phil... I have a stock gear knob for sale for $30 if you are interested, not in the best condition, but have a better one in better condition for $60 :P
charles..do you know if the standard 34 gtt threads are m10 or m12.. i STILL dont have my car back so cant check it... cheers
I'm pretty sure the R33 and R34 have the same thread, so I'd say M10.
Yes from everything I have seen the 5 speed has a M10 thread and the getrag is a M12.
Hey stupid question but how easy is it going to be to to wire up the led's in the gear knob. Is ther already a power supply near there or can you piggy back onto say the cig lighter or something?
Should be very easy. Basically just an earth and power. The power supply can be used as an ignition so it lights up all the time or off of the headlights. I'm going to do it off of the headlights.
Bahahahahahah that's insane.
I understand Phil, that most gear knobs won't suit the R34 GT-R setup where one needs to lift the collar to access "R".
Any word on these?
So I had a bit of a look into this for you Terry. Am I correct in stating that you should be able to use any gearknob because the actual "lift up collar" for reverse is independent of the gear knob itself? The only difference between our ones and yours is that yours is an M12 instead of the M10 thread (lucky bastard!).
:laugh:
Get a Nismo Duracon Gear Knob.
It's a hard plastic so won't wear out so easily.
+ I am thinking about one of these for my car, as I don't want to wear out the stock one I have.
You can get a Aluminium one...
But they can get hot in the summer if the sun shines down on it.
Yeah I don't mind those Duracon Nismo ones.
Either way we shall see what this supplier says and if we can get them in a M10 i'll definetely put up a group buy, or just buy one myself.
They come in 10mm / 12mm.
32865-RN006 = Looks like the part number for White.
32865-RN007 = Looks like the part number for Black.
Suites Nissan 5 / 6 Speeds.
- http://www.visionr.c...=detail&cid=409
Hahahhahahahaha shhhhhh let's not go there :P
Also you homo, can you confirm about the reverse lift up thing in your 6 speed, it isn't actually part of the gear knob hey, it's underneath and therfore you can run whatever gear knob you want on it?
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
