should be ok to just unplug, think it only splices into the ignition system and bypasses part of it for a designated time, so if you unplug it, it should still work as normal. Isnt it easy enough to just unplg it and try it out?
Not really it seems quite messy under the steering wheel I'll have to tale the interior panel out tommorrow and see if it just unplugs
hopefully it will be fine
Cheers
PS if it works anyone want a FET turbo timer with R32 harness for 50-60 bucks
  • 5 months later...
Hi guys, I am thinking of installing a racecar-style ignition on/off switch and am thinking that using a turbo timer harness may be the way to go.
Do turbo timer harnesses hook into both the 'on' and the 'start' circuits?
Thanks, Ben
Theres no need for them to hook into the start wire because they only need to keep the car running when key is off. Should hook into ACC, ON and constant power.
What exactally do you want to do? have the normal key to turn everything in the car on then having a race style switch to start?
Thanks, I gathered the same with the start wire. I want to have one click switch to turn the car to on and a push button for start. I don't think I need an acc switch if I go straight to on. I don't want to use my key at all but would probably want to wire is so rant I could still use the key if I wanted to.
That's gonna make your car quite easy to steal
And therefore if it was stolen and recovered insurance would refuse payout
yeah, this
It would have to retain a key to turn on the electrics and push button to start only when the key is in. The only way I could see it being safe
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
    • Final thought for now. Obviously the reason I was in there was to check everything is OK cooling wise, pull out the radiator to flush it etc, but I have to say the factory has done a hell of a lot of thinking about air management in a way they never did back in the R chassis days. The Redsport/400rs have (from engine forward) 2 large shrouded fans - radiator (incl AT cooler) - AC condenser - Intercooler Heat Exchanger and Oil cooler. There are shrouds and foam around everything to keep it pretty well sealed, which is good in that they have it sorted from factory, and bad in that I can't make any meaningful improvements there. The second red sport pump water pump is mounted in front of the rad in the airflow, so I will see if there is somewhere else I can stash that (unlikely, it is tight in there). The horns which are also in the rad airflow will be moved somewhere else, and hey who needs 2 when 1 would work For track days, I can also remove the lights which would block some airflow. Factory has already taken the smart option of ducting all air that went through the oil cooler down and out of the engine bay. This pic is taken from below looking up, so air comes through the cooler at the top of the pic then hits the shroud and is directed down and out of the engine bay through the engine bay lower cover Which of course is good for oil temps, but doesn't help the rad as it diverts 10-20% of airflow away So, no big improvements to be made here, I'll flush the rad out and put it all back together.....
    • It looks so incredibly busy in there! 馃槷
    • Next..... That escalated quicker than an Elon and Donald break up! I'll post up a specific DIY for radiator removal on these, but all I'm saying is that if you get a workshop to change your radiator for any reason and they give you a $1000 bill for it, go and hug them and thank them for not charging all the hours it took.....what a bastard of a job. I'll make some adjustments as I put it all back for faster access in the future, but it was a nightmare.
