Hey guys,
Today while under my bonnet I noticed a pssssh sound. Sounded like air running through something.... or leaking. I started listening around and heard it from a piece of hose on my boost controller. I pinched the hose and the sound stopped. I applied soapy water all over the hose to find a leak and found none. I started pinching other random hoses and the sound was there, but if I pinched the hose coming off the TB which leads to my Y piece to my boost controller/waste gate line, the sound stops. The sound is audible across the hole line, not where I initially thought.
The line which comes from the TB to trigger the BOV has been Y pieced to support my boost controller. If I pinch the hose from the Y piece leading to the BOV, nothing happens. If I pinch anywhere on the line going to the boost controller, the sound stops. If I pinch the line going out of the boost controller to the WG, it stops. If I pinch the light right up near the TB, the sound stops.
Is this a leak or is it a normal sound? My Greddy Profec B reads -94 most of the times. Sometimes I get really bad hunt and it drops to -80 and revs follow.
Any ideas guys? Should I just replace all the dry hoses? Is 3mm ID the best overall size to go?
Cheers
https://www.sau.com.au/forums/topic/360967-pssssssh-sound-from-vacuum-hose/
Standard internal wastegate. I was actually thinking it could be this because
pinching the line right near the wastegate nipple will make the sound stop! There is nothing else to pinch so that tells me the sound is coming from the wastegate because if it was before the wastegate it would still be audible. Ahh shit balls lol.
Sometimes I pitty you lol. Where oh where does it end..
Cut a sample of the hose (for size) go to repco and buy a few meters of it for under $10. Go home and install the BRAND NEW HOSE that does not have any holes in it. See if the leak is still there?
How bout you also note, if you undo the hose from its source (with the motor off) and suck/blow in it, does it makes a hiss sound from the pressure of your own breath?
Happens when I blow into it and goes away when I pinch at the wastegate nipple. Is this a problem? Cause of my random 14psi spikes? The sounds is also easy to pin point from the wastegate area.
Edited by SargeRX8
    • +27605538865 Powerful Lost love spells caster by Mama to work in 24hrs with Strong magic and Psychic Reading Skills. Do you miss your lover and want him /her to come back to you? Do you want your ex to be in a relationship with you again? If you miss your partner/soulmate and cannot think of living this life without them, then perform this fast spell will help you make your lover come back to you. Imagine a love spell that could bring back your Ex, return a lost lover, or fix a broken relationship. The love spells were created to restore the romance and strength of deep love while erasing the heartache and pain of the past. By restoring these emotions with a clean foundation, my witchcraft rituals offer hope to those who fear resentment and deep anger from a lost partner. specializing in lost Love Spells, Marriage Spells, Protection Spells, Spiritual Healing, Fortune Teller Many people still question whether love spells work or not, permanent or effective? This can be based from past experiences where they tried some spell casters but not fully satisfied with their results or the love spells worked for just a short period and sometimes even never saw any results. To avoid such situations you have to be careful with spell casters you approach, some are limited with certain Spiritual powers to cast good love spells to help people in their relationships Customized Love Spells This love spell is customized and suitable for bringing the one you love to you. If you are not with the one you love for any reason, we can cast this love spell to shock and manipulate the one you love into coming to you. This spell unites lovers, which includes reuniting lovers.+27605538865 Mama Naledi
    • +27737053600 Revenge spells and Death spells to punish someone until you are fully avenged By Mama Shamie Revenge spells to teach someone a lesson they will never forget using voodoo revenge spells. My spells of revenge will inflict serious harm on your enemies, so do not use my revenge spells unless you are sure. Revenge spells for cheaters & your enemies. Revenge spells and curses to help you get the ultimate revenge. Voodoo revenge spells for cheaters, ex lovers, your enemies & people who want to harm you. Give life for life, eye for eye, tooth for tooth, hand for hand, foot for foot & to punish your enemies with revenge curses & spells for revenge. If someone has truly wronged you and you want to get back on them with the ultimate revenge spell, then try this witchcraft death revenge spells. The most precious asset we have is life so the death revenge spell is by far the most powerful revenge spell in the world as it will lead to the death. I only cast the death revenge spell when you have given me all the proof that the person you want to cast upon deserves death as punishment. Spells for revenge to cause your enemy to have sleepless nights & frightening dreams. Banish bad dreams & nightmares if someone has cast bad dreams revenge spells. Call or Whatsapp me on *+27737053600*
    • Spell to Stop Divorce in your marriage +27605538865 Stop Separation with my Spell to stop Divorce Lost love spells caster The forces involved in this witchcraft spell can reestablish the loving bond between you and help to build a sturdy, loving relationship from which to start anew. Despite any previous hardships or issues, the spell work will reestablish the strong bonds of friendship and love upon that the wedding and relationship originated. Have faith, these rituals are very powerful and can reconnect you and your partner during a strong and harmonious relationship. If you think that your partner is considering either separation or divorce, use this magic spell to stop the forces that are calling it quits your relationship. It is very necessary that you act with haste since prolonged negative energies create difficulties for the efficiency of this spell. If your partner has already breached the subject of either separation or divorce, use the spell immediately to rekindle the love that’s the idea for your marriage or relationship. Stop a Divorce or Separation
    • Court Cases and Legal magic spells +27737053600 Win a Case Spell Mama Shamie People are accused of things they never do and others did they but need a retreat, with my Court Case Spells, you can win any kind of case whether you are guilty or not, are very effective magic spells; Court Case spells are used to solve any type of court case or legal matter problems. If you are suffering and tired and the case or any legal matter that you are going through is not ending then you may contact me for a very strong court case spells. and you overcome it. If you having problems in winning Court Case then you may try casting this spell and it will surely give you positive results. Court cases magic spells are designed to rescue you from search legal accusations in a very convincing way. Black Magic Court Case Spell ✝2️⃣7️⃣7️⃣3️⃣7️⃣0️⃣5️⃣3️⃣6️⃣0️⃣0️⃣ Black magic court case is very powerful magic spell specifically cast with black magic features to generate more magic energies to relive you off the hook from being convicted no matter whether you are guilty or not, the spell has enough power to make your case either dismissed or ruled in your favor. The power of magic can play tricks with the evidences with the aim of disappearing some of them which would have lead to your conviction; there is no limit to where the spell can end until the target is reached. +27737053600 Mama Shamie
