Start car, better with a mate, so he can blip the throttle.
Take your oil filler cap off and see if it is breathing heaps = indicates blowby = rings/liners worn. Keep a rag handy,so you can half cover the hole just in case it starts to spit oil.
Do it with a couple of cars if you can so you can see the difference.
And by breathing ill audibly hear air in the system? or it will blow oil around?
Ill give it a crack.
Edited by Mattw_83
  • Replies 44
Apparently grabbed another gauge for the second test. I'm getting further tests out of curiosity. Leak down etc. And as previously mentioned.
If no good... Say hello fg xr6t. It's s bit of boat... But NEW
I agree. I will be. Im no mechanic mate, but of all tasks how complicated is a compression test. Remove components, put the gauge in and kick it over. repeat. How many variables for f**k ups can there be.
But yeah I'll be doing it anyway
At WOT?
At WOT?
I can only assume. This is the general practice yeah? Ill ask specifics this arvo.
There just isnt anything from the factory that has the same appeal. Closest is a turbo falcon. But it honestly feels like your driving a bus in comparison. Plenty of poke though out of the box ill give it that.
before i bought my r32 gtr, i compression tested afew that realy appealed to me.
i took them for a nice drive to get the engine hot, then did the compression test at WOT
my gtr came up 160 - 162psi accross each pot...
different methods will get different results
yeah do the test at running temp for starters, and full throttle, keep the test consistent across the cylinders for example if u hit 3 compression strokes on the 1st cylinder, do the same for the other 5, dont just keep cranking until it stops going up. if your still not sure do a leakdown test it will tell you everything a compression test doesn't.
yeah test drove one and gave it heaps. Manual fg. Goes great. Sounds good too. I was well impressed, but that feeling faded fast when I got back into the old skyline and realised I still f**king preferred it. Makes parting with the 50k painful.
Be nice if those clowns at Nissan released something comparable...
a skyline is a performance car an xr6 turbo is just a family car with a turbo slapped on
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
