I'm currently running the same SARD 700's you are while making 400awkw at 21psi. My duty cycle is sitting on 79% but that power had been made with quite a bit of mechanical tuning as well. Happy to give a full list of specs if you need. I'm running normal 98 RON so you shouldn't have to change unless you really want to go to E85 in the near future.
what percentage is considered dangerous, i.e anything over 90%? when do injectors lose efficiency?
The only problem with running injectors at 100% is that you are not controlling the fuel.
The injectors will happily sit at 100% all day. So will injector drivers in ECU's
But if you are at 100% then you are at the limits of the elements with fuel control. If a condition changes, eg. 1 more psi, colder charge temp etc, there is no adjustment for this.
This is the only reason that 100% DC is not recommended.
i used to run 1650cc on my pfc
Sorry to bug you Marko but, can I have some details, I was told that the max you can run was 1000cc or atleast with any sort of resolution ?
Im running ID 2000's and they are fine.....
Im using 700's. Based on the scaling of my MAP sensor and running 1.6 bar with a rich 11.5:1 afr I think there is room for well over 400kw from the 700's, provided you can make that power below 8500 rpm. My calculations show that at 1.7 bar boost and at around 8000 RPM i'll be brushing up against the 100% duty limit.
My hope is that i'll achieve 450kw at the tyres with this setup, and at the most with the addition of water/methanol injection. Im using a nismo in tank pump too.
Edited by GTRNUR
Well my plan is stay on pump 98 so I'm hoping I can get away with 700's.
I'm also going to run a pierburg fuel pump intank which supports 360lph, compared to the 044 which runs 200lph it is 66% more efficient.
I'm going for a clean setup :)
Not many ppl know about the pierburg apart from the odd workshop. They run them in the mercedes amg series and the bugatti veyron
Course you'll get away with them.
700cc - ~700hp, that's @ factory pressures too.
I don't even see 70% duty with 370rwkw from my 700 Sards. About 65% i think is the most.
ok - i'll let crd decide when i take it to jim
Nice well Im just going to dump some ID 1600's into my HKS rail and see how she rolls.
I was always told by a certain person that a PFC will not run over 1050CC injectors...
Awesome, thanks guys.
The id1000's are almost half the price of id1600's and id2000's, 1600's and 2000's are 250each ouch...and I thought jap injectors were hefty
In my old setup I had bosch 1600's (indy blues) and they were only 90bucks each
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
