Will My Sard 700Cc Injectors Support 400Awkw?
I'm currently running the same SARD 700's you are while making 400awkw at 21psi. My duty cycle is sitting on 79% but that power had been made with quite a bit of mechanical tuning as well. Happy to give a full list of specs if you need. I'm running normal 98 RON so you shouldn't have to change unless you really want to go to E85 in the near future.
what percentage is considered dangerous, i.e anything over 90%? when do injectors lose efficiency?
The only problem with running injectors at 100% is that you are not controlling the fuel.
The injectors will happily sit at 100% all day. So will injector drivers in ECU's
But if you are at 100% then you are at the limits of the elements with fuel control. If a condition changes, eg. 1 more psi, colder charge temp etc, there is no adjustment for this.
This is the only reason that 100% DC is not recommended.
i used to run 1650cc on my pfc
Sorry to bug you Marko but, can I have some details, I was told that the max you can run was 1000cc or atleast with any sort of resolution ?
Im running ID 2000's and they are fine.....
Im using 700's. Based on the scaling of my MAP sensor and running 1.6 bar with a rich 11.5:1 afr I think there is room for well over 400kw from the 700's, provided you can make that power below 8500 rpm. My calculations show that at 1.7 bar boost and at around 8000 RPM i'll be brushing up against the 100% duty limit.
My hope is that i'll achieve 450kw at the tyres with this setup, and at the most with the addition of water/methanol injection. Im using a nismo in tank pump too.
Edited by GTRNUR
Well my plan is stay on pump 98 so I'm hoping I can get away with 700's.
I'm also going to run a pierburg fuel pump intank which supports 360lph, compared to the 044 which runs 200lph it is 66% more efficient.
I'm going for a clean setup :)
Not many ppl know about the pierburg apart from the odd workshop. They run them in the mercedes amg series and the bugatti veyron
Course you'll get away with them.
700cc - ~700hp, that's @ factory pressures too.
I don't even see 70% duty with 370rwkw from my 700 Sards. About 65% i think is the most.
ok - i'll let crd decide when i take it to jim
Nice well Im just going to dump some ID 1600's into my HKS rail and see how she rolls.
I was always told by a certain person that a PFC will not run over 1050CC injectors...
Awesome, thanks guys.
The id1000's are almost half the price of id1600's and id2000's, 1600's and 2000's are 250each ouch...and I thought jap injectors were hefty
In my old setup I had bosch 1600's (indy blues) and they were only 90bucks each
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
