I'm currently running the same SARD 700's you are while making 400awkw at 21psi. My duty cycle is sitting on 79% but that power had been made with quite a bit of mechanical tuning as well. Happy to give a full list of specs if you need. I'm running normal 98 RON so you shouldn't have to change unless you really want to go to E85 in the near future.
what percentage is considered dangerous, i.e anything over 90%? when do injectors lose efficiency?
The only problem with running injectors at 100% is that you are not controlling the fuel.
The injectors will happily sit at 100% all day. So will injector drivers in ECU's
But if you are at 100% then you are at the limits of the elements with fuel control. If a condition changes, eg. 1 more psi, colder charge temp etc, there is no adjustment for this.
This is the only reason that 100% DC is not recommended.
i used to run 1650cc on my pfc
Sorry to bug you Marko but, can I have some details, I was told that the max you can run was 1000cc or atleast with any sort of resolution ?
Im running ID 2000's and they are fine.....
Im using 700's. Based on the scaling of my MAP sensor and running 1.6 bar with a rich 11.5:1 afr I think there is room for well over 400kw from the 700's, provided you can make that power below 8500 rpm. My calculations show that at 1.7 bar boost and at around 8000 RPM i'll be brushing up against the 100% duty limit.
My hope is that i'll achieve 450kw at the tyres with this setup, and at the most with the addition of water/methanol injection. Im using a nismo in tank pump too.
Edited by GTRNUR
Well my plan is stay on pump 98 so I'm hoping I can get away with 700's.
I'm also going to run a pierburg fuel pump intank which supports 360lph, compared to the 044 which runs 200lph it is 66% more efficient.
I'm going for a clean setup :)
Not many ppl know about the pierburg apart from the odd workshop. They run them in the mercedes amg series and the bugatti veyron
Course you'll get away with them.
700cc - ~700hp, that's @ factory pressures too.
I don't even see 70% duty with 370rwkw from my 700 Sards. About 65% i think is the most.
ok - i'll let crd decide when i take it to jim
Nice well Im just going to dump some ID 1600's into my HKS rail and see how she rolls.
I was always told by a certain person that a PFC will not run over 1050CC injectors...
Awesome, thanks guys.
The id1000's are almost half the price of id1600's and id2000's, 1600's and 2000's are 250each ouch...and I thought jap injectors were hefty
In my old setup I had bosch 1600's (indy blues) and they were only 90bucks each
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
