The id1000's are almost half the price of id1600's and id2000's, 1600's and 2000's are 250each ouch...and I thought jap injectors were hefty
In my old setup I had bosch 1600's (indy blues) and they were only 90bucks each
ID 1600's 2000's. Do it. You will never have to think/worry about it again. Sell the 700's and the changeover will not be that bad. :thumbsup:
I found ID1000's for a bit over $ 100 US each, reasonable ?
im interested in where u got those prices as well - there are some fakes floating as well so need to be careful when purchasing
Just be careful on where you get them. I was told mine were ID2000s but are really Bosch 2200cc. They are pretty much the same injector just not modified like the genuine IDs are
so are the id's modified bosch items? what is the difference?
Mine arent genuine ID's either, they are the local Xspurt modified ones but at $650 who cares. They are 1000cc Bosch EV14 injectors with a guaranteed spray consistency, local warranty and they idle perfectly. I will be giving them a workout soon.
http://www.xspurtinjectors.com/
Basic Specifications Nominal Flow Rate - 2225cc/min @ 3.00 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Thats straight off the ID website!
And for anyone that has issues with these injectors not being able to idle or what not.... here you go!
The guy I bought them off says they are identical but Injector Dynamics just adds on the fancy anodised tip and charges extra for them.
Let me report back with my results after the tune as most of us are still sitting on the fence. My mate who owns autostyle had a gtr 'dardvl' which made 450awkw back in the day and I think that also had 700's
They are ID ones by the looks of the extender, Keep in mind they are only Bosch injectors flow matched and tested, I asked the guys at AZNEW today when I ordered my proflow fittings, they said theirs come in Bosch boxes and are unmodified.
I had a bad experience with the bosch 2000's one injector flowed 7-8% more at idle and fouled the plug real bad.. Im guessing injector dynamics found the same problem and is probably why they push the flow matched sets that you pay a premium for..
From my experience you will need to run bigger injectors then 700's to make 400kw+. When I was making 374 RWKW I ran 700cc Sards with a duty cycle of up to about 96. At the advice of my tuner (a reputable one)I upgraded to Sard 800's to allow for more headroom. This allowed me to run a bit more boost and make 390 RWKW. Now the dc gets to about 85. This is with a -5 2.7 setup. I wonder why the difference between my experience and some others in this thread? Is it just a difference in dyno readings? I know of others with similar results to mine.
Tim.
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
