I just got defected today driving my uncomplied unregisted r32 gtr from the mechanics back to my house on a permit.
I had no front bar because it was at the crash repairs getting some cracks fixed, and whilst i was driving it home my front right indicator fell off unknowingly.
the officer deamed the car unroadworthy and defected me. the car will be getting complied sometime in the near future maybe 3-6 months.
will this defect have to be removed (rectified) before i go to get complied or when its getting complied or after? or is it just nothing to worry about?
Thanks.
https://www.sau.com.au/forums/topic/361051-defect-on-permit/
There is a dedicated defect thread in this forum for questions like these. Otherwise we'll have hundreds of defect threads from various posters.
Expect this thread to be locked and/or removed.
You'll find your answer in the defect thread.
:thumbsup:
I wouldn't worry too much - I know this isnt the exact same situation but me and a mate of mine both took our R32's through Regency around the same time for a RB25DET conversion, his was defected, mine was not. I don't believe there was any difference at all in how the cars were checked and the owners treated.
Get the defect notice signed off once you go through so you can hand it into the rego office to get rego for your car.
You might have to pay more for it though as it's meant to be a different type of inspection to your ID one to gain rego.
Easy done though.
I would have laughed at the cop, as the car is uncomplied it is, and always was not compliant with ADR's and therefore is defectable. But as the car has to be complied you are in effect clearing the defect when you get it complied, just rip the sticker off, it means nothing in this case.
true.... but leave the sticker. its not worth the immenant fine that you would get
Rip the sticker off if you never plan on regoing the car but leave it on if you do plan on getting rego.
They would have defected the vin number of the car so he would need to get it cleared off the system so he would need to get his defect paper work sorted at the same time and removing the sticker wouldn't be a good idea haha.
as the car hasn't been complied, there is no VIN in the system. The VIN the car will end up with will be an 1MPORT xxx xxxx VIN which the car hasn't got yet.
Anyhow there is no harm in leaving the sticker on but i still would have laughed at the copper.
Those VIN numbers were issued with tho old Import scheme, It will be given a VIN, 6U90 - then your chassis no, more Zeros added to to take it up to 17 digits if required.
so if my vin/chassis numbers are in the system with a defect to there name, when they add onto the numbers for compliance it wont show that it has a defect on it when i go to get rego?
Thanks.
Thanks.
Im pretty sure when you take the car in for inspection, it wont be "on the system" yet as a car on the road. Doing the roadworthy to get rego is clearing it at the same time also, so once inspected, they would then add you and at the same time it would be cleared of any defect.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
