Hi,
Im currently re-doing the wiring on my car.
I have no standard wiring/plugs at all.
Im up to doing my alternator, from my understanding i need:
1. big cable that runs to battery (distribution block)
2. Cable to signal the alternator to 'run' (off the same switch as ecu power)
Now i hear i need a check light aswell, what exactly do i use as the check light and where di i wire it?? Im using the stock alternator with the big 2 pin plug then the big terminal for the + output.
Anything else i need alternator wise?
Thanks
https://www.sau.com.au/forums/topic/361057-alternator-wiring/
