hey guys,
So my problem started with a dead coil. Replaced with yellow jackets and its a bit better, but still not 100%
Any ideas? Is there anything additional i have to do to get them to work? Idles a bit.. chuggy. It shakes a bit like its misfiring but it dosnt feel like its that bad?
Also the engine light is no longer on, so thats a start..
Please help me, i just busted my balls taking that damn thing apart and im really frustrated.
https://www.sau.com.au/forums/topic/361063-installed-yellow-jackets-what-now/
leads,plugs?faulty lead makes my telstar sound like a wrx,with just 5 cyl firing properly.but i'm by faaaaaaaaaaaaaaaaaar no expert.oh i meant by faaaaaaaaaaaaaaaaaaaaar,no expert.rich.pinch.gif
Edited by GT ARRRGH
drawing from my vast array of knowledge....little,car should run fine with stock ecu.but if you do get tuneable ecu you will get the best out of better induction,spark,airflow yada yada.i'm tryin to help ya but i aints got much knowhow just yet.hopefully one of the uber brains on here will help with diagnosis.:thumbsup: sorry maybe not induction(see i said i aint gots the smarts)insert yokel laugh here.
Edited by GT ARRRGH
Yeah im not sure my self. Im running stock ECU, Is that alright? Its an N/A also.
a good auto sparky may be of service too.
Leads in a coil over spark system?
Check your plugs, probably wouldnt hurt to replace them, reset the ECU (Unplug battery and hold brake down for a bit then plug it back in... Should only do this with a stock ECU) Clean AFM, give everything a good check over etc
looks like he has an r34. so no ignitor. it's built in to the coilpacks isnt it?
i'd check the wiring harness that plugs into your coil packs. make sure it's all good... as well as check / replace your spark plugs etc.
Edited by Munkyb0y
+1 if the looms/wiring are hard and stiff, there's a likely problem. Should be supple and flexible - opposite to a Fap.
Checked the coils, tightened them up and checked loom.. It looks alright..
Dunno what it could be! :(
As a few ppl have said - change the plugs. Its simple and cheap, so its the most sensible next step. Post up photos of the plug tips so we can have a look.
+1
Not exactly hard, should have been the first thing u did really
Also make sure the crank angle sensor hasn't moved. If the timing is way out it will be rough.
The who what? How?
Plugs were changed about 3 weeks ago also btw.. they should be alright pirate.gif
The who what? How?
He probably means the cam angle sensor - its the round thing with 3 bolts holding it on at the front, just to the right of the RB25 logo on the cam sprocket cover. You need a timing light to check it.
Have you located the misfiring cylinder? Have you moved the coilpack then spark plug to see if the missfire follows?
Got a pic? lol still not 100% sure.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
