So I was driving to work today and when i was coming to a stop I put the clutch in and the revs just dropped to 0. I thought it was a bit strange, but I kept going. About 20 meters down the road it happened again. While on my break at work it drove it around and it was fine when it was cold since the revs would stay up but when it got warm they just dropped to zero every time i stopped. I noticed it was alot worse when the lights were on and also when I turn the lights on I can hear a squeelings noise from the engine bay. Is this an alternator problem? I thought it was something to do with the fuel pump untill I noticed the lights making a difference with the problem. Before I get flammed I did a search on the topic and couldn't find what I needed.
thanks, Dylan
Had an almost identical problem with my 32 gts-t, fine when it was cold but once it had warmed up or if it was a hot day the revs would just do whatever the hell they wanted, hunt like crazy, idle at a constant 2000rpm, or just drop straight to 0 and stall (this being the most common). However mine wasn't an electrical problem, took it into ASG who told me i needed to replace the stock ECU, my injectors were leaking and something about the AFM being wrong. Probably not a huge help to you but something to make sure isn't the case I guess.
no it wont be the alternator
check the airflow meter plug, make sure it is secure
look for any damage or excessive dirt etc
reset the stock ecu (undo battery terminal in boot (the ground cable) and press brake pedal)
if it still happens you need to get a consult cable and run stock ecu diag
  On 16/04/2011 at 2:05 AM, Dylaan said:
last time I had the afm off I noticed that there was a fair bit of gunk built up in it, should i clean this out? Why do I need to press the brake pedal while reseting the ecu?
yes, and pressing the brake pedal drains any residual power from the ECU
thanks, Dylan
heres something weird...the same time u posted this my car started doing the exact same thing :unsure:
I find if i rev the crap out of it it often fixes itself, personally i think it is gunk buildup on the o2 sensor ..but it could be a number of things..
Hey mate i had exactly the same problem with my old R33, took to a place called NT Performance Turbocharging in Western suburbs(melbourne), dropped it off in the morning and by the afternoon i had it back, car has been fine since !!! Worth maybe giving them a call, Simon there really knows his stuff with skylines!
dont goto a workshop for something basic like that
read what the others have posted
learn how to debug and fix it yourself
the ECU has on board diagnostics so theres nothing magical a workshop can do that you cant find out
well I think it's the alternator still because my belt has been squeeling for a while, sometimes it turns over very slowly but always starts, when I turned my lights on the revs would always dip a bit. And yesterday after I reset the ECU and cleaned the afm the car was running okay untill I turned the lights on.
Check all 6 spark plugs see if all of them are covered in unburnt fuel, if they are. Check the ECT sensor
(engine coolant temperature sensor) if the sensor is dead, it over fueled the piston during idling and
will cause it to stall.
ECT sensor located at the thermostat housing by the way.
It would be the ECT sensor if the problem only occuring when the engine is hot or at the working temperature
and run smoothly while cold.
would that cause the idle to stick on 2000?
cause mine did that last week but hasn't done it again, It was on a dyno few weeks back it was running rich but didnt have time to source a problem.
There is another sensor at bottom of radiator, is that just a gauge sensor? I never put it in when I changed the radiator initially, but since I have put it back in I've been having these problems.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
