Hey Everyone,
i thought i would see what everyone else thinks on this issue with my GTR, since its the weekend all the shops are closed so i cant take it anywhere until next week :(
This is the problem i am facing, since last night my car hasn't been boosting properly (going to 0.4 bar when it normally goes to 0.8) my exhaust note inst as loud as it normally is when your pressing the accelerator. It all happened when i hit max boost and high revs (7000rpm) it just cut out on me, boost was down and exhaust note was very different all of a sudden. The engine still revs but its very doughy and you can hear the turbo spool a little but not as much. could it be a possible blocked cat? not sure what else it can be, i look at the hoses on the intake and BOV and all seem to be fine.
Any ideas where i could take the car on the gold coast if its not a cat issue?
https://www.sau.com.au/forums/topic/361085-possible-cat-blocked-on-my-r34-gtr/
my car is still making power (0.4 BAR boost) but the car is just struggling to get there and the exhaust is very quiet, if it was a turbo wouldnt it make no boost?
Edited by K33P UP
also another thing to add is that both inlet pipes are sucking and the main hose to the plenum is making a fair bit of flow. so the motor is getting air.
if it was the exhaust wheel in the turbo's the intake should be producing flow correct? also there doesnt seem to be any oil usage just alot of fuel dumping out
Edited by K33P UP
Well if you've only blown one turbo then the other one will still be boosting.
Check cat first, quick and easy.
The second turbo will spin, but wont make any boost as the air blows back through the compressor of the dead turbo.... So since OP is getting boost, its not an exploded turbine.
Load up the car on a dyno or going up a hill and see if the cat starts to glow red. If so its a blocked cat, had same issue with mine when it was stock
lol wouldnt it be much easier and safer just to drop the cat and look? if a turbo is half rooted (also being ceramic) the last thing u wanna do is spin the engine at 7000+ rpm
Probably not, loading up meaning 2500-3000rpm up a hill in 4th, so its under load, if the cats blocked doing this for about 10-15 seconds will make it glow, seems easier than jacking the car up, and taking the cat out...
each to their own, im just saying if theres any chance it could be the turbo i wouldn't be boosting it. when i did my standard turbo the bearings went causing the impeller to spin out of balance (very slightly) causing it to just nip the sides of the housing which chipped tiny bits of the blades off, mind you as soon as it blew i didn't boost it at all on the drive home but if i did im sure it would have just smashed apart the impeller wheel completely and if it were a GTR theres a good chance it will go through the intake side.
yep it was definetly the a blocked cat, here is a picture of what it looked like from the front. pretty impressive i must say.
so now i have a new stainless high flow 200 cel cat, the car has never run so good..... makes me think the cat has been blocked since i bought it. best $300 i have spent yet!
thanks for your advice everyone :)
Regards,
Dom
Edited by K33P UP
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
