yeah we could probably work something out to have a look maybe
if you want the plates make me an offer i cant refuse, see how you go.....
That would be awesome to have a look. Are you planning on bringing it out for the Toowoomba cruise?
came and looked at your car thurrrrsday?? afternoon
its a minter.... very nice, i wish mine was white
Thanks mate. I am really happy with it. I would love to get some photo's of mine car and your's if possible?
Any change of mind about bringing your car out of hibernation for the T'bar cruise?
Would be nice to have more then 1 Toowoomba skyline turn up, cause I have not been having much luck with other owners
i would but mine is not registered it just sits in the shed.... and for what it would cost me to register it for just that day its not worth it hey
if you wanna come look at mine ill consider, it and you can get your photos here if you like
instant rego can be arranged you know :P
i've recently moved up to Oakey / Toowoomba Gunmetal Grey R32 GTR ;)
Awesome. You doing anything this Sunday. big bunch of guys from Brisbane area are cruising upto Toowoomba. Would be good to see you there thumbsup.gif
I am keen to get amongst it but stupid friends have to hold stupid elaborate birthday parties that are on the same stupid weekend >_<
That sucks. Guess you will just have to make the trip down for happy laps at lakeside next weekend
What time sunday? And where? .. i'll see what i'm up too! Normally home in Brisbane though over the weekend :)
Around 10-10:30 up at picnic point then cruising down to Withcott for a feed
We could have a catch up tonight sometime if you guys are keen? suss out some details and what not?
lets bring thursday night laps back! but seriously...no
Yeah big no for Thursday Night Laps. Don't really want to have to deal with the 17y.o in there VN commy trying to race, I get enough of that on my way to and from work rolleyes.gif also don't want to have to deal with the police.
What about tomorrow say 6 at the Kearney Springs softball/touch carpark? Or we could do evening during next week?
i might head to picnic point too just look for my white ute.... ill come say hi if i can but i wont cruise i got a skyline to put together instead
where at picnic point chris??
another one ?
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
