Ok I'll give that a try see if that worjs
I use electrical contact cleaner which is essentially the same thing bar the price. Bunnings have them cheap.
Sad you couldn't turn up today cos of the car. We were wondering where you were.
Had a fun drive today. Even got to swap cars and drove a 350Z. Bloody spectacular cars even stock standard. I personally believe a it would run rings around my 180 on the track apart from the straightaways. I wouldn't be surprised if it was 3 or more seconds a lap quicker with me behind the wheel of both cars (depending on the track layout).
The Perrenti got all the attention from people up at Picnic Point and had a few requests for pictures. Nobody cared bout the 3 Japanese buzzboxes parked right beside it :(
That's only because I wasn't there ;)
I start mine at service stations and have people walk over saying "excuse me but what is in that".... And I giggle lol
So what's the review of the 350z I've never been on one? I know they sound sexy with an exhaust (much better then the raspy vg30dett's)
I think you would have completed the picture, Nick :)
They are solidly built cars. Drive brilliantly and by the seat of my pants, I believe they have greater mechanical grip in the twisty stuff. Their seats also hug you as good as early GTR buckets (I rate them the same with 33GTR ones) with the addition of power adjustment and heating.
The engine has plenty of torque from the get go and nothing beats an N/A for response. Steering is very direct and the brakes are good but a bit too touchy for my liking. Didn't get to brake too hard in it though so I can't tell how they compare to the setup on the 180.
Suspension was stock and didn't roll too much in the corners. Rode bumps and imperfections brilliantly - this made me hate my coilovers even more!
I really ended up liking the car very much in the brief time that I drove it. My comparison is of course based on my experience driving the old girl and being in a few skylines in my time (not just TSO member cars). I know they're newer so I am comparing apples to oranges :P
Makes me wonder what a turbo'd 350 would be like LOL
If you can squeeze turbos into that crowded as sin engine bay without a masters in "wherethef**kamigoingtoputtheseanomitry" ill sell you my first born child lol... Supercharging though :yes:
You need to take me for a run in the 180 broseph
APS used to make bolt-on turbo kits for the 350. Some 350s for sale here are turbo'd.
The old girl isn't anything special. She makes a great street car - got the brakes and takes corners like a pro but she can get unsettled depending on what sort of bump you hit mid-corner. Coilovers just suck plain and simple. Bilstein shocks and eibach springs all the way IMO.
Today's little session revealed my current alignment setting lacks turn-in compared to my previous setting but I don't have to fight the wheel so much in regular day-to-day commuting. Sad I can't have my cake and eat it.
When you do get a ride, you'll miss the torque of the LS and I thoroughly enjoyed the torque of the VQ. Boost however, can get addictive.
Edited by me_larr
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
