Who fixed it for you?
She got a new lancer, it was about time the oldies settled on what car they were getting. All the questions the old boy was asking me was driving me insane
Pretty sure you can figure this one out, Chris.
Guard needed some massaging, intercooler brackets needed straightening, and some plastic welding was done. All corroded/broken bolts were either removed or drilled out with new ones put through. Definitely wasn't a straight forward job but it got done one weekend. Paint was done by someone unknown to me but it was certainly better than the paint previously on there.
There...I've given you one very distinct clue already as to who done most of the work as it happens to be his specialty :)
Man of many skills - some of which I'm just beginning to discover.
Lancer evo X bathurst?
Think its afm from what I can find out pretty common problem not sure how reset ecu other than scan tool I've got one to do obd2 but not obd1
Just disconnect the battery and tap the break a couple times, turn lights on etc, turn key etc etc....to bleed the system of all power. I also left my old liner disconnected for a couple hours to make sure she was well and truly in reset mode when you fire it up the next time.
When I first do this to mine it won't idle... Second start is fine
Well now you'll have to give it a chance to learn the engine again. I had to do this for my GTST when I put the intercooler on and also when I put the pod on. There's actually a procedure to *helping* the eccs learn...like, a set way that you should drive it so that the computer can fine tune all it's tables (seeing that all engines are different but the computers all have the same maps etc etc)
But yes, if it's chuggy/surgy I'd go over all your vacuum lines, pressurised pipework and all your sensors. Give it all a tighten-up and clean with contact/carb cleaner - your engine will love it (even if it doesn't fix that particular problem)
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
