Hey Chris, was just thinking that if possible one should do that Clifton drive later in the arvo as it all looks quite pretty in the low sun! When I went thru there last it was about 3-4 in the arvo and the sun was directly behind us....very scenic indeed especially with some of those cliffs/gorges
Can't beat the old ling long spec 235/45/17s bake like no tomorrow $100 a side to replace...
+1 man
Those things at a reduced 30 pounds or so were grippy as hell...must be a cheap soft rubber instead of a cheap hard crap rubber ;)
That's the spirit.
I should be back on the road and joining you guys in my own car come December/January hopefully.
Otherwise, I'll gladly ride shotgun :)
In the meantime, I'll just dream of all the cool stuff we get to eat at Tbar HQ, Xmas time. I'll bring a carton with me.
It's only October and already I'm getting impatient LOL
That's the spirit.
I'll be CC, redbull redbull, dry and lime'ing up ;)
That's the spirit.
Yes hurry up already ;-)
And I totally agree - that feed your bro put on last time round Chris was amazing! F some people can cook well!
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
