Rudds pub at Nobby just north of Clifton do a massive feed. The pub itself is a historical landmark (and falling apart)
The Bull and Barley at Cambooya get a lot of bikes and cars on sunday cruises and they also do a pretty good meal. You probably passed the wheatsheaf at east Greenmount if you went the warwick toowoomba road.
Lots of little sneaky pubs around the downs, not much else to do I guess
The main thing is you make it a point to join us next time.
After you get your mechanical/electrical issues fixed up of course ;)
Big loss whenever you're not with us.
Oh and you can lead the parade cos you seem to know where all these hidden pubs are :thumbsup:
:D Growing up out that way you get to learn all the watering holes, and the sneaky routes home. And will defo make the next run now that I have a shiny new set of coil packs. Shoutout to ESP!
As I mentioned, I can do a day run and a few sharp ones for Chris' bday but am out for the night.
Oh I suppose I could tee something up ;-)
Does she have some rust issues Ibrox?
Lol Nick, i don't even know what to say to that haha :D
My car...kinda nothing major though..that I can see. Its more for peice of mind
Thanks Clint - still a bit surprised at how much gear they stick on top of the Neo. Can see why a lot of people would go to a mechanic with a 34 just for something like a sparkplug change etc....interesting stuff, but she pulls nicely ;)
I always thought they weren't too bad - I know that mine was sprayed from factory with a rust retardent rubberised coat to the whole chassis. At first it looked like I ran over fresh road works but it's a rust protectant hehe. But, I'm not sure if all come with that or if it's just a certain part of Japan where they throw salt on the roads etc etc
yeah got no excuses not to get the tune done now, except the feeling that i'm going to need a new clutch once she's putting down a few extra killerwasps
Really am astounded the amount of heat generated from a 5min putt over to your place, considering what it's going to be like with more boost running through it :/
Edited by sonnyQ
Haha yeh well it is one of the consumables on these cars - we all go through at least one of them during the time we own the car. But that all comes down to your driving style too Clint - some people inflict a lot of wear on them and some match rpms and what have you and wear the cluch much less - I try to heal toe where possible ;)
Haha yeh but it wasn't too bad mate - if you had been driving for longer we would have to have let the car sit for an hour or so before you can touch it. And as for the boost...I wouldn't worry about it hey, she's nicely set up to run an extra couple pounds. All the RB's will go up to their operating temps of 84-86 degrees or so as quickly as possible, open the thermostat, and then stay there regardless of boost when you're driving around normally. Obviously if you thrash it around a track for longer than 5-10mins or so she'll get hotter - but for everything else I wouldn't worry :)
You always want your motor to heat up as quickly as possible (to operating temp) because that's where it runs best and is most efficient fuel wise.
What sort of tune are you aiming for? You don't really need anything if you just want to run 2-3 extra pounds - the computer's fueling tables/maps will cover this extra air easily :)
Edited by tommis85
^^ just saying that last bit because a lot of people underestimate the Nissan ECU. So many people (me included) will try to flash tune them, stick boards and chips in to them, nistune etc, only to wish they hadn't =/ From my experience I could almost advise to just stcik with your ECU until you upgrade injectors and what have you....the ECU is more than capable of controlling things until you max out injectors and airflow meters etc etc
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
