Yea, that person should be either the owner's son or something. Thai looking guy yea?
If I'm not mistaken, it also has Ksport brakes? Don't think he drives it hard enough because it always looks so clean :)
Someone should hit him up and get him to join us on one of our runs.
We need another funky colour so the Abom doesn't get all the attention!
yeah, I think he lives around perth st area as well. Was having a bit of a chat to him one night, he was telling me about his dramas with manual conversion using the auto ecu :P
10am eh, when and where are they cruising?
don't like swifts and focii (unless its a hottie driving) or flat brimmers!
It's on their facebook page - Last Place Cruising.
Meet at the lookout at 10am.
10:30 cruise starts heading out to ravensbourne lookout and photos taken.
12:00 - 12:30 back into toowoomba parking at the duggan st parking then into the gladstone for lunch n drinks.
I suppose from ravensbourne, we could then decide to go our way and have lunch at the withcott pub?
I personally wouldn't buy a swift nor a focus but apparently some of these guys have had their share of modded imports in the past. I have been known to discriminate against certain cars and mod trends but I'm trying to change my stripes :P
Did you get a number or get him to have a look at this thread?
Could get him to join us unless of course he likes driving/hardparking alone :closedeyes:
Yeah I might head out. Was going to go for a nice drive with Amy in the 32 on Sunday anyway. Might go to this instead
I'll prolly come along with you. Meet up at at HQ around 9:30?
I have no idea where this silly lookout is and cbf'd googling. I only know that north st passes straight thru the heart of derelict central in Toowoomba :P
Alternatively, could meet up at mine cos I think I'm closer to the lookout yea?
Edited by me_larr
Pretty sure I am closest of all!
LOL alright then. We'll have to do our own sometime soon to make up for missing this one?
Besides, I haven't gotten the call from Chris to say I can pick up the new girl.
At least I know it's not a rushed in/out sorta job...or perhaps he just wants to keep the evo for a little bit to enjoy himself :ph34r:
I say we do exactly that Mr Nick! I'd be down with that. Right now I could do with some Thai/Chinese!
And that's good that she's all sorted now! You'll have to show me it one of these days - best not talk about it on here ;)
apparently farmers arms at cabarlah puts on a pretty good spread.
checked out that fb page as well, what is their theme????
They don't have a theme as far as I know. They just welcome anyone and everyone. All cars seem to be welcomed as well as long as they aren't idiots and abide by the rules of the cruise.
I didn't make it. Nobody seemed keen enough and I'm not rocking up alone.
When's the next TSO + E run? :P
I spent most of the day either running errands or watching the bathurst 12hr. Fking Nissan decided once again to prove they're shit by supplying blindfolds to each of their drivers and use it they did! :dry:
Can't wait to see what cars run at next year's. I'm surprised that none of these rich people chose to use an LFA or a Koenigsegg or an Aston Martin. If they can spend stupid money fitting a 5ltr V8 into a Ford Focus and turn it RWD, they should have gone for something that exotic just for kicks.
Edited by me_larr
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
